need a measurement
need a measurement
hey guys I'm working on my t56 magnum swap and need a measurement for tranny placement.
I need the centerline measurement from the bottom of the shifter (under tge car)to the center of the output shaft of the transmission
thanks guys will post pictures soon
I should have my transmission out this weekend. Which direction do you need a measurement in?
I need the vertical measurement between the center of the output shaft and the bottom part of the shifter itself
it would also be nice if I could get the measurement from the frame rails up to the bottom part of the back of the transmission that holds 5th and 6th gear
