Cleaning injectors
Cleaning injectors
Whats a good way to clean injectors? Is additives good enough or i saw somewhere t soak the tips in carb cleaner any thought/advice? Also thought on seafoam in the ls2.
Been doing this over 20 yrs and have never found anything that cleans as well as 40+ PSI of gasoline. The old style injectors were poorly engineered and had all sorts of problems (spray pattern, wild swings in lb/hr, etc). The injectors they have now do not clog...and if they somehow did, cleaner will not help you.
If you want to see a bunch of smoke come out your exhaust, drop a vacuum line into a bottle of Trans fluid.
