mp122's brand new!!
#45
seems like it equates to "roughly" an 80rwhp jump over the 112 with the same setup.
#46
So is that heads / cam as well? That boost pressure seems low otherwise. The engine must be flowing well.
#49
That thing has a much better inlet design how it wraps around the circumference. Also the exit doesn't have those reversing / sound ports that will help efficiency as well. Looks great!
#51
112 was designed a few years before the 122. 122 is just a better design all around..just look at the casting and machining between the two cases and not to mention the extra helix twist of the rotors. not many have spun these as high as i am and i plan to put the 122 thru the ringer as well
#52
So the blower is back on the car and a tune is schedules for this Wednesday. I'm bring both my 2.8 and 2.6" front pulleys. I've attached some photos i took throughout this drawn out process
As you can see with the back holes lined up, the opening and front 4 holes are not properly aligned. I had to open up that hole almost 2"
Also the rear cover that houses the gears to drive the rotors was 0.200" thicker on the 122 than 112. Therefore i relocated the front two holes forward and slotted the rear four so that the rear pulley position where is was with the 112 mounted.
Here is the freshly machined plate with the slotted and drilled holes as well as the intake opening enlarged.
the blower reassembled
Finally back in the car!!
And of course once it was on the car i found this interference! UGH! Thankfully i found it and was able to clearance it before turning it over.
#60
mods are 2.6 front pulley, Volant intake, ls2 tb, alradco radiator, cooling mist meth kit stage 2 I think (50/50 mix) and ls7 clutch
