Excel Spreadsheet - Engine Speed vs. MPH
Hey all,
I've been trying to decide on a TR6060 and 9" IRS gear ratio for some time now, and put together a spreadsheet tonight that you might find useful. If you have any suggestions as to how to improve it, give me a yell. Right now, it provides comparisons between:
![](http://i1345.photobucket.com/albums/p663/Fuzzylog1c/Misc%20CTS-V/ExcelMPHRPMCalc_zps279f22a1.png)
Enjoy!
- The 2.97 CTS-V wide gear ratio with 4.11, 3.73, 3.55, and 3.31 final drive ratios
- The 2.66 C6 Z06 wide gear ratio (0.75 5th and 0.50 6th) with 4.11, 3.73, 3.55, and 3.31 final drive ratios
- The 2.66 C6 Z06 close gear ratio (0.80 5th and 0.63 6th) with 4.11, 3.73, 3.55, and 3.31 final drive ratios
- The 2.29 C6 ZR1 close gear ratio (0.84 5th and 0.67 6th) with 4.11, 3.73, 3.55, and 3.31 final drive ratios
Enjoy!
What considerations are you trying to balance as you compare the ratios? If you give us an idea of what you're trying to determine then maybe we can provide some ideas on different things to calculate.
As a couple of examples, I have a spreadsheet that I've played with for my Subaru, which has an STI 6-speed in it. Since I auto-x the car, I've got it set up to calculate top speed in 2nd gear. I also have it calculate highway cruise RPMs, since the car is primarily a daily driver and I don't want to kill mileage. (That was more a concern back when it still had a 5-speed in it, as I was trying to balance highway MPG vs having a 5th gear that would actually accelerate on long straights during track days. But anyway...)
If you're looking for good 1/4mi times and have some idea of what sort of trap speeds your combo will be capable of, you could have the spreadsheet calculate RPMs in gear at that trap speed so you can be sure you won't have to shift to 5th.
By the way, is the spreadsheet too wide for you guys? I'm running at 2560x1600 resolution, so I have to be careful not to build something that forces people to scroll left/right a whole bunch.
nice work!
Just so everyone knows, you can do quick calculations like this with the following formula (It's factored out and simplified)
------------(RPM)*(Gear Ratio)*(Convertor efficiency)*(Tire Diameter)*(Pi)
MPH= ----------------------------------------------------------------------
----------------------------- (Final Drive)*1056
Where tire diameter is in inches. For manual cars, use "1" for convertor efficiency
Lol 294mph with 3.31 in it... That would be awesome. Could you imagine building a huge power FI motor and walking a Bugatti through its top speed? It would take miles and miles but it would be cool.
