What did you do to your V today?
#2243
How much weight is left on ea valve from hollow to solid, did ya know this?
I lost 10g ea by swapping from solid to hollow on my new Ferrea's in TFS heads...
Greetz
Ron
Greetz
Ron
#2244
My stock LS6 valves are right around 74g on the the intake and 65g on the exhaust. And they are bringing some darn good money right now too. I should be able to sell the LS6 heads pretty easy.
#2245
- Fixed my sunroof by breaking it. Went out to a wicked hot car, opened the windows and the sunroof to vent out the heat while the A/C started to kick in. Went to close the sunroof and it partially closed, then went back to full open. Pulled over and stood on the door sill and looked in from above as I tried to close the sunroof again. There was a plastic/rubber strip in the driver side rail - part of the top of that strip was torn and was catching the sunroof when it tried to come forward. Looked at the passenger side rail and that strip wasn't there, so I yanked it out of the driver side rail. Sunroof closed, problem solved!
No idea what that strip is called or what it's for, but I figured since it was already missing from the passenger side, I wasn't going to hurt anything by pulling it out!
#2246
#2247
Sure, I'll try to remember to do that tomorrow. I still have the rubber strip thing around here somewhere, too... at least, I don't think I tossed it yet. If I find that, I'll post a pic of that, too.
#2249
A couple days delayed, but here are the sunroof pics. First shows the groove that the rubber/plastic strip came out of, indicated with the 3 yellow arrows. It's the narrow groove (maybe 3/16" wide) closest to the opening to the inside of the car, not the 1/2"+ wide groove.
Here's the rubber/plastic strip, kind of lying on its side. The piece in my hand is the very top of it, and is what was starting to crack away from the rest of the strip.
And here's the strip showing how it sits vertically in that narrow groove. I never bothered to look under the glass to see what was actually catching on the strip, I just yanked it out.
#2252
Apparently broke something in the clutch pedal? Not really sure.
During my morning commute Tuesday I pushed down on the pedal and heard/felt something pop. Clutch continued to operate, but the pedal just didn't feel right, and would kind of hang up partway down. I made it to work, but decided to swap cars later in the morning (so I wouldn't have to drive the car in afternoon rush hour traffic with a suspect clutch) - went out to the parking garage and the car wouldn't start. Poked my head under the dash, clutch position switch was in place and plugged in. Cycling the pedal by hand felt and looked normal. Pop-started it and drove it home; wouldn't start once I got it home. Maybe something failed inside the clutch position switch? I'll have to pull that off later to check, but I'm heading out of town for a few days, so that'll wait until my return.
#2253
AAIIIC, if you reinstalled your clutch return spring, it probably just broke and both pieces are sort of hanging in there.
Same thing happened to me with 9,000 miles on the odometer. Removed the spring and never looked back.
#2256
#2257
I had mine in the Pittsburgh Vintage Grand Prix car show again. Going back to watch the racing today. Some guy asked me if I bought it from a guy named Brian. Does 07CTSV have a stealth grey one with Black TD wheels? I think they meant him, pretty sure he’s not far from here too.
