Is there really any danger in driving the V with no exhaust?
I would be very interested in your ideas about how removing the catback could cause this issue.
I was trying to show how an exhaust flow could affect downforce levels and using proven real world example might help explain what I was talking about. As neither of us have had this issue I don't think there is anymore we can add to this topic.
Most 10.5 radial and outlaw drag cars are dumping the exhaust through the front fender just ahead of the wheelwells with turn-ups to take advantage of the downforce it creates in order to take every opportunity to keep the front tires on the ground. Must be a little something to it.....
Here is a little areo info http://www.autozine.org/technical_sc.../tech_aero.htm
"Lift
Another important aerodynamic factor is Lift. Since air flow above the car travels longer distance than air flow underneath the car, the former is faster than the latter. According to Bernoullis Principle, the speed difference will generate a net negative pressure acted on the upper surface, which we call "Lift".
Like drag, lift is proportional to area (but surface area instead of frontal area), the square of vehicle speed and Lift Coefficient (Cl), which is determined by the shape. At high speed, lift may be increased to such an extent that the car becomes very unstable. Lift is particularly serious at the rear, you can easily understand, since a low pressure area exists around the rear screen. If the rear lift is not adequately counter, rear wheels will become easy to slip, and that is very dangerous for a car travelling at something like 160 mph."
"Lift
Man, this conversation is getting intense... ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Mine will activate at lower speeds as well by the way. And running the cutouts open on the track, I've noticed no ill effect. Still good (and amusing) discussion going on here.
Edit: My long term plan (if possible) is to somehow run side exit exhaust through the rockers similar to the VR. Possibly still retain the cutouts to run through a simple muffler in the stock resonator location with some turn down tips in case I need to drive highway a long distance.
#33
Running the exhaust though the rockers would be killer, I know i've looked into it a few times and it would take cutting and sleeving the "frame rail".
#34
Later you claimed cars are designed to cause lift for fuel mileage?! Ahahaha please give me that source.
So instead of a high frequency noise and vibration near a sensor that is directly related to the stability system you think the added exhaust pressure is lifting the car? Or maybe, it's acting like a hot air balloon with all the extra heat! Gimme a break.
#35
What!? No one here jumped off the deep end except you! Lol the exhaust caused the car to get light?! Do you hear yourself? Yes I have read your argument in later posts and it is just comical. Also, the exhaust added underneath the car would technically negate your lift thought. If you were to add air underneath a wing it would increase the speed underneath, no? Causing a loss in lift. you are claiming this is happening at only 100mph (apparently 100+exhaust is enough to loose traction). While an f1 car at 220 may cause problems, a 4,000 sedan is laughing at you. And so are we.
This is what i'll call an airfoil
![](http://smoknjoe.tripod.com/pic/fig1.jpg)
and this is what i'll call a wing
![](http://www.thebeijingshop.com/images/carwing.jpg)
They are the same thing just one is turned upside down to make negative lift Also known as downforce.
When and area of high pressure relative to the area of low pressure travel across an airfoil lift is created.
Cars are inherently like airfoils witch means that if no corrective actions are taken the car creates lift. A corrective action would be to add a wing to a car to create downforce. Another way to create downforece without a wing is by using a Diffuser
The diffuser works by expanding air back to ambient pressure. It uses Bernoulli's principle, such that the pressure decreases while the velocity increases. Since the pressure below the car is lower than on the side and above the car, downforce is produced in the diffuser. A way to increase the effeteness of the diffuser is to "blow" it
A blown diffuser is basically a way of using the exhaust gases to interact with the diffuser airflow To re-energize the air at the back of the diffuser to create more rear downforce
![](http://www.formula1-dictionary.net/Images/blown-diffuser-red-bull%20RB6.jpg)
So back to your argument "adding air underneath the car would technically negate your lift" No because you are adding more pressure and increase turbulence which also slow down the air flow witch increases lift to the underside of the car
I hope we can all agree that the V1 doesn't lose traction at 100 mph, but i'm not sure how many of you have been higher. 120? 140? 160? If you have traveled at those speed or been in a car traveling at a high rate of speed you know that cars can get squirrely. This is because the increase in lift. (higher speed = Higher lift)
So my theory is that with the increase of exhaust to the underside of the car this raises the pressure witch creates more lift at a lower speed. witch causes te car to get squirrely Witch causes the stability control to engage.
Also stability control also uses wheel speed sensors to know if it needs to engage or not. Not just the YAW sensor. So even if the YAW sensor was giving it a wacky single to the computer you would most likely get a service stability control message not the stability control being enabled.
And its fine what we disagree (part of the fun in life) it would just seem if you make the comments less personal attacks and more about the subject we could all share and learn more about a subject that non of us are experts in.
#36
Anyway... "There's something on the airfoil!"
