1000hp V1 on eBay
and by his shop does he mean his own shop? if so then he could answer those questions pretty easily. the general info is useful even if people never make use of it.
Edit.... This thing is 20 minutes from me... If anyone wants it checked out let me know. I'll head down and scam some more pics and such.
Its got built lower end and stuff. Its got a Callie's, Manley, JE rotating assembly. I'm sure its not stock compression anymore. Edit.... This thing is 20 minutes from me... If anyone wants it checked out let me know. I'll head down and scam some more pics and such.
Wait....if a V2 craddle bolts up to a v1, (with the exception of the gas tanks), does that mean that a V2 diff and axles will fit a v1 cradle IF the mounting points r to be welded to the v1 to fit the v2 diff?
If so; then...
V1 cradle -$200 (i dd my car so id need another one)
Oem V2 diff - $500 (ebay)
Oem V2 axles $ 600 (ebay)
And i can just weld the new diff mounting points on the v1 cradle and end up with a v2 diff, which is a lot stronger than the v1 diff and itll only cost $1200-$1500 ( not as good as an 8.8, but a whollllle lot cheaper?
I guess IF either the v2 axles fit in v1 outer CV's or v2 complete axles/cvs fit in v1 knuckles..
Can this be a possiblity??
If so; then...
#33
I had a camaro before this v...the tracks I parked in before vs now are a few inches narrower (camaro is wider than v)....surely some of that is axle length? No? Gen2 ctsv and gen5 camaro share platform.
#34
If so; then...
If so; then...
Budget 2500 for the swap including fab work. Might as well go bulletproof and Bolt in at that point.
#35
Fab work will be done by me, so it wont cost me anything, and im not sure how much power the v2 diff/axles can hold, but im sure its alot more than my stock diff and i dont plan on ever making 1000whp (although it would be nice, but im ok with future plans of 600-700whp, which im guessing the v2 stuff will hold)
I think its worth looking into, if the v2 stuff only requires the new diff mounting points on the v1 cradle.
