Shimming ls7 slave
Sorry to hear about your struggle here.
I'm facing a clutch install soon and to keep things simple I plan on going with a complete ls7 kit including the flywheel to keep it all GM.
Anybody had this struggle using the matching set of GM ls7 clutch,pp, flywheel and slave using the ls6 pressure plate bolts at 48lbs?
The Katech spacer is for a single mass LS6 clutch with the stock slave. The shims they sells are the correct ones and I don't know why they would say its not for the V. These cars share the same transmission and slave style so the shims will work. If you call and talk to Tick, they will tell you they have shimmed several LS7 clutched V's.
"Hi Wes, Our shop foreman has a cts-v as well he lets his wife drive, and he has the same LS7 clutch in it and says now his wife has to put the pedal to the floor before it will engage smoothly. An LS7 has a 1-1/2 stroke to its master where as a CTS-V has a 1 stroke master. He suggested the use of a C5 or CTS-V specific clutch would work better with the LS7 slave, and you are 100% correct a shim would not help this issue. We are currently in the process of making a tutorial video series on a few things people have a hard time with, one being clutch hydraulics and why you need to shim and why you don't need to shim. If there is anything else I can get answers to feel free to hit me back up on here and i'll collaborate with our mechanics to try and find a more positive response.
Ticket: http://tickperformance.freshdesk.com...sk/tickets/544
Eric Lawson - Sales Specialist
Tick Performance LLC - Specializing in GM LSx Performance"
Thanks Lolly. I think I saw that on Tick's site last night when I learned about these shims. See above for what Tick had to say about that though... A bit confused right now.
Wes- I may have understood that wrong but it seems like they are referring to the stock cts-v (short/stock) slave, which does require the katech spacer.
The ls7 slave shouldn't require a shim, but some of us aren't so lucky
Tick said master so im assuming when you press the clutch the ls7 master pushesh more fluid then the stock cts master. Meaning the ls7 slave is suppose to extend and contract more then our master can push thats why it might be a problem
So... here's an update. If anyone's still following this, please post up your thoughts in response.
I got to drive the car a little more today than I have over the past week or so, since once I got up from night shift I had the rest of the day off. I made a few observations that may or may not change your opinion on my specific situation.
1) Getting into reverse is still an issue. Rolling into it is easy breezy, and getting into it with the engine off is equally easy. (this isn't new info, just somewhere to start)
2) The clutch doesn't seem to be dragging in any forward gears, but I only tested with the wheels down (didn't have a 2nd person to watch for me if I jacked the rear up). For all forward gears I put the trans into gear, pressed the clutch pedal all the way down, and revved and goosed the engine to 4,000 or so RPM. No movement (besides the engine torquing a bit...love that feeling!). I did the same in reverse and the car moved a bit, BUT that might've been a fluke. My garage floor apparently isn't perfectly level and I wonder if the engine torquing around caused the car to roll a bit. It was getting late and I dind't want to keep trying it because it's a bit of a loud experiment for the neighbours. lol
3) I've mentioned that some of my other shifts have felt....off. I've had a couple (but not consistent) grind-y 2-3 shifts that I thought were maybe caused by clutch issues. But the more I drive it, the more I wonder if they've been driver error. I'm still getting used to the new pedal engagement height and I wonder if my muscle memory is making me start the shift before my leg has the clutch pedal depressed far enough.
4) I experienced out-of-the-norm notchy-ness shifting to 5th and 6th the other day. Again, I was thinking it had to do with the new clutch. I don't have any other explanation for it, but today shifting to 5th and 6th was as smooth as it's always been...wtf? It was significantly cooler outside today than it was the other day, but does the ambient temperature have anything to do with how my car is shifting?! lol
In summary, today's driving was problem-free aside from the dicking around it would take to get it into reverse. This is different from my very brief drives to work over the last couple days. So, reverse issue aside, I've had a few days of problem-free driving and a few days of "something's not right" driving since this clutch has been installed. Oh, and a random day where getting into reverse was cake... too bad that didn't last. Again, wtf? lol
Last, I'm not sure if I've mentioned this or not but to be clear, I do have the (gray) Creative Steel motor mounts (with heat shields) installed, as well as Creative Steel's "soft, black" transmission mount. So sagging, etc shouldn't be an issue.... but maybe this could still be an alignment issue...?
Thoughts, guys?
When you bleed it, how many draws (pulling the pedal back up) do you get to almost emptying the reservoir? I can get 3 pumps (3 pushes, 3 pulls of the pedal) before the reservoir is down to just above the hole at the bottem where the fluid is drawn from (where you don't want to go past because then you'd be sucking air into the line). If yours is the same, then I would say my master cyl and yours are both performing the same in terms of the volume of fluid it's moving...
If the case was that the stock master cant push enough fluid to extend the LS7 slave correctly... then EVERYONE who has done this mod, would be having this problem or similar.... and thats not the case.. it seems obvious (to me atleast) that you have extenuating circumstances that are causing you to have issues.
#33
So, has anyone had this problem running a GM LS7 flywheel, GM LS7 clutch and pressure plate mounted with factory V1 pressure plate bolts torqued to 48lbs operated by a LS7 slave cylinder?
Or, does it make sense to run the above combo with a stock V1 slave and Katech spacer?
Looking for a trouble free daily driver clutch on a stock motor....
#34
I have a LS7 flywheel/clutch/ pressure plate and LS7 slave from luke @ lindsay cadillac.
torqued to 48lbs i believe... never had an issue bleeding it and it was exactly as described by previous peoples. engaged right off the floor for about 500-1000 miles and then was almost stock location. its been great so far.
edit** I used arp flywheel bolts with their moly lube and instructions... reused the stock pressure plate bolts at the advice of luke.
#35
#37
Originally Posted by FuzzyLog1c
...briefly, the issue here is that the stock CTS-V master cylinder is not capable of producing enough fluid volume to drive the slave through its full 0.700" (18mm) travel. In fact, based on my testing this weekend (had the transmission out) and a couple of technical discussions with McLeod engineers, I strongly suspect that we're getting less than half of that travel. My testing with both the LS7 and McLeod RXT clutches indicates the stock CTS-V slave works best with about 0.300" (7.5mm) preload. When Philistine finishes his Tilton 76-875 project, it'll be a game-changer because we'll finally be able to set our slaves correctly with the recommended gap and get better performance than we have now...
#39
I've had 3 clutches in my car... the stock dual mass setup... a ls7 clutch and flywheel... and the current mantic single er2 one... car has always since it was brand new with 500 miles hated first and reverse... i have heard everything from changing engine and transmission mounts to hydraulics fix the prob with no clear resolution from anyone? it seems there is a curse to the first and reverse gears in the gen 1 V
#40
Having the shifter base bolted to the car and not floating with the transmission is a problem according to a Tremec rep I spoke with at the Charlotte autofair. It's never surprised me that it doesn't shift that well especially when you consider it has rubber in not one but two places between the shifter and the transmission.
Sure, you can upgrade bushings etc but there is still play there guaranteed.
Also, the shift linkage only works one side if the shift mechanism coming out of the transmission and it looks to me to put in a bit of a bind when operating. A new linkage should be built that completely captures the shift mechanism in the transmission. There's a thread on this somewhere on this forum.
Do the stock v1 slave and the ls7 slave have the same piston sizes?
