please help identify where these clips connect under dash
hey guys
need a little help with a couple of clips under the dash
first, if you follow the swps clip's wires back to it's origin, there is also a dual wire (grey/blue/white) with a blue connector at the end. Can you trace where that goes and let me know if/where it's even connected to anything?
My steering has been complete sh*t for a few years- I just noticed it a couple days ago and I'm thinking this might be a small part of the problem (ultimately I think i got a junk rack right out of the box, but that's another story)
next, there's a connector right next to the steering column that isn't connected to anything-- is this also disconnected on your car?... If no can you trace it is well?
you may have to have the bottom kick/knee bolster piece off to see the swps and upper plastic/metal pieces off to see the column (unless you are way under there on your back), and I'm not asking anyone to go removing panels, but if you have access now, or can check next time you are under there, I would really appreciate it..
thanks
thanks
who knows. I can check.. where is the close out panel. if it's just for a light, f it..
I thought about dropping the column again to see if it was on the top side
I have access to wiring diagrams, but they're system specific- if I don't know what I'm looking for it's useless..
