n2mb DIY Shift Light and Settings
1 Post
Making a shift light for your n2mb wotbox (2step, nls, etc)
Once the female end of the serial cable is cut off, it will be difficult to determine which wires are from what pins. The best way to determine which wires are from what pins is to "tone" the wires. Write down your findings to map out the entire setup. You will need pin 2(-) and pin 6(+).
These LEDs in question are 20mA.
The Cable is a 6ft DB9pin RS232 serial cable.
Settings to know on the n2mb...
At idle, no pedals pressed:
Clutch 5.00
TPS 1.00
Pedals all the way down:
Clutch 0.04
TPS 4.28
My clutch pedal info may differ from you guys... but the TPS should be similar. This will help dial in the n2mb more specific vs leaving the default setting of ~2.90. Raising the number to 4.10, 4.15 as I have it, allows you to do a burnout easier without kicking in the 2step.
Just some info I figured I'd share since I'm starting to see guys pop up with the n2mb left and right now. LOL
Clutch 5.00
TPS 1.00
Clutch 0.04
TPS 4.28
