Why the PATHETIC rwhp ??
Adam, and everyone else who wants to sue:
I can't believe I'm saying this (since I'm in law school) but suing is not the answer.
If car enthusiasts keep up this "sue the people who build the cars we love" thing, the automakers will quickly abandon us.
With rare exception, they don't make any money on limited edition performance specials like the CTS-V, since they cost a lot to develop and sell in small numbers. They justify them as halo cars for the rest of the lineup. If we, the enthusiasts, make it MORE expensive for them to serve up these cars, they are very likely to wash their hands of the likes of us, and shift their energy to normal family cars, trucks and SUVs.
We're a small but passionate market - but we are a SMALL market. And if the automakers have to worry about a lawsuit everytime they rate the horsepower of a performance cars, that makes it that much tougher for the car nut engineers to justify a program like the CTS-V to the bean counters.
Originally Posted by WhiteDiamond
Adam,
Your arguments, while intentions may be somewhat good, are truely baseless. Just because so and so at ws6.com got a 3.x rwhp gain/loss for X amount of weight does not mean it translates to another vehicle the same. The Corvettes torque tube and rear mount tranny are a negligible issue in the dyno numbers between a Vette and F-body. The much larger difference is the IRS versus a live rear axle.
Also, before you go getting all hyped up about some lawsuites and such, it is wise to remember that you have very little to gain from pushing such action. The owners will loose value, GM will reconsider the vehicle and in the end the consumer who purchased looses(ask any of the Cobra owners affected).
(I) am saddened that people buying CTS-Vs are not getting what they paid for, and the reason I mention litigation is because they need to be aware of their rights, including the right that Cadillac explain why the car is not making the power it should.
It would be wise to see some higher milage dyno's of the CTS-V and find out what TM parameters exist in the PCM. This car is, after all, a Cadillac and may have much more TM parameters present than the Z06.
Also, the Vette does not enjoy the luxury of 14" Brembo's and actually has smaller rotors(even the new C6 has smaller rotors). The CTS-V does not enjoy the lightweight wheels the Z06 has(don't start the WS6.com says stuff again, even day to day dyno'ing on the same dyno can produce the difference you are talking about).
As for the weight of the wheels and brakes again that is BS. That can account for some difference but not 30 RWHP.
The reality of the situation is that 17% to 20% is the drivetrain loss expected from a vehicle such as the CTS-V with IRS. It would be closer to the 20% number is the flywheel is truely a dual mass unit(for your own dyno information, I got over 10rwhp for a aluminum flywheel and ACPT CF driveshaft on my 98 WS6). The last time I did some math, 20% of 400hp is 80hp. 320rwhp is about right. Lets see some higher milage dyno's now.
Todd
Todd
The simpler solution is the motor jusst isn't making it's advertised power.
I am however saddened by people that get shafted and then feel they aren't empowered to do something about it, especially when there is precedent. If I bought a VCR took it home and the record button didn't work or played movies with the tracking off, I would take it back and ask for a repair If they told me the poor tracking was "in spec" when they advertised otherwise I would then ask for a refund. I wouldn't be scared that Sony would quit making VCRs.
Adam,
Again, you are trying to compare the numbers to a Corvette Z06 which has a engine rated higher and may have much less computer interference. The fact of the matter is that a 330rwhp CTS-V is making more than the advertised 400bhp. You may compare the CTS-V to your M series, but there are way too many variables in a driveline to make this comparision. Reciprocating mass taxes power and the BMW may be less in this scenerio.
It is also important to take notice of the current Z06 dyno numbers. The 405hp Z05(2002 - 2004) is dynoing in the 355hp to 360hp range at the rear wheels. Some are higher. This shows that the LS6 in the Z06 is underrated. Even using a low 15% loss through the drivetrain, the car should only see 340rwhp +/- a few and most of the Vette dyno operators will tell you that 17% is the current loss factor they use for the M6 cars.
So, Chevy gives us an underrated 405bhp Z06 Corvette and a damn near perfectly rated 400bhp CTS-V. I believe this is the way it should be, as the Vette is GM's supercar. More power to Caddy, but they are delivering the numbers they advertise and magazine track testing has shown the dyno numbers may actually be inacurate, as times tested show the motor to be closer to the 350 to 360rwhp range.
Todd
Todd
LS1Tech Co-Founder
The engine rating is accurate. The restriction is in the exhaust and the intake airbox. Since these cars are Caddys, they were designed to minimize engine and exhaust noise. They are very quiet in stock form. Simply replacing the silencer/resonator on the midpipe of the exhaust system with an X-pipe setup will get you about 18-20 rwhp (dynojet proven), and it will sound much better. The stock mufflers on the back are restrictive as well, but I'd give up some power for quieter exhaust.
The potential is under the hood, and extracting the power is the fun part. The '99 Cobra simply had an engine that was a piece of crap, that isn't the case with the proven LS6.
Tony
Tony
There will always be factory freaks some of our members have freak FBods. Of course some ZO6's will have higher numbers than others, but the CTS-V must be properly marketed.
Originally Posted by Dreamin
It was my understanding that mfg hp claims are hp at the crank with everything in place... smog equip, intake, full exhaust... not the "raw" engine numbers.
Todd
LS1Tech Co-Founder
Originally Posted by Nine Ball
Nope, GM rates the engines based on the engine itself. It is only the internet crowd that tries to correlate the actual rwhp figures with the rated figures. Why should we trust GM hp ratings anyways, look how much they underrated the LS1 f-bodies at 305 hp, when they were making 305+ rwhp stock. Would that be 0% drivetrain loss? lol
307 rwph here with a lid and a cat back God love GM for underrating these things
The Z06 LS6 and the CTS-V LS6 engines are exactly the same, except for oil pan and exhaust. And that is why the CTS-V LS6 makes 5 less HP than the Z06 LS6, because of the different headers/exhaust.
#32
LS1Tech Co-Founder
Originally Posted by ls6caddy
GM rates their engines with everything attached (exhaust, accessories, etc.).
If they always rate the vehicles with the engine in the car, then the 98-02 Camaros/Firebirds would have been rated at 345-360 hp. Not 305 hp.
Inconsistent rating methods it appears. I know the LS6 under the hood of the CTS-V is the same engine as the Z06, so at least we know the engine itself isn't a piece of junk, haha.
Ratings? Who cares. I know the potential
#33
He is comparing the HP from the M5 and the RWHP but dont the German calculate the HP different? I had a VW That was supposedly 150 hp. It make 148 at the wheels so its not just GM or a capital case.
#34
Originally Posted by cvp33
The 14" rotors actually rob horsepower as well. Rotating mass plays a big role in net HP. This was actually proven on tuner television about a month ago. During their build up of their RSX they added a CAIK, exhaust and larger brakes. Went to the dyno and actually LOST horsepower. Certainly the CAIK and exhaust had increased the power? The engineers got involved and sure enough the larger rotors had taken all the power gains because of the increased rotating mass.
#35
After much dyno testing on our Mule Caddy, we have found that ours makes about 402FWHP. Of course we are going by the standard 17% loss based on our previous knowledge and what has come in the shop. Most corvettes lose 17-18% while camaros only loose about 15%. I would not say that Cadillac is lying to everyone. I think that for the most part it is accurate in the horsepower numbers they give. We have been dyno testing an Engine for GM High Tech and on the Engine Dyno it made 412FWHP. It is the same engine that the 2004-2005 Caddy has and was supplied from the same. In the car it lost 17% and the air was horrible on the day of the testing. I am not sure the numbers are really that bad. We are makeing 625FWHP/524RWHP with our caddy right now.
#36
Moreperf: So your test mule made 334rwhp (402 *.83) ?
What about the car used for the intake testing, it only made 324rwhp ?
https://ls1tech.com/forums/cadillac-cts-v-2004-2007-gen-i/154088-new-cold-air-cts-v-proves-great-improvements.html
But the real question is: what do stock 02+ Z06s make on your dyno?
#37
The last bone stock Z06 we dyno'ed made 339RWHP. It had no performance modifications at the time of the dyno. After a Cam, Springs, VaraRam, Headers and Exhaust it made 419RWHP. Our test mule was made 412FWHP. We estimate a 17% loss on our Caddy (Which dyno'd at 324RWHP). You multipy the 400FWHP (That caddy says you have) X17% and subtract that gives you 332RWHP. You also have to account for the horrible exhaust and headers and the numbers you see are very close to accurate. There is no accurate % for what you should go by. The only sure fire way is to pull an engine, engine dyno it, reinstall it and chassis dyno it for accurate readings. I think this is a waste of everyone's time since there is no sure fire way of telling what the % rate should be. What we have found is close to what GM specs are.
#39
White diamond has hit the nail on the head.
CTSV rear Rotors weigh almost 10 pounds more than a Corvette rear rotor.
Plus the IRS soaks up some additional power.
we have dynoed five or six CTSV's and have consistently produced 325 to332 HP at the rear wheels.
When they heat up, they fall off as computer compensates...
Also, low results may be caused by one of the air intake ducts becoming dislodged or partially blocked, which may trigger a lean condition and a low octane table reversion...
Anyway, this is a great car. I love mine. And it is so easy to make faster!!!
#40
Its simple.......intake and exhaust. You people that are complaining actually think GM would build a different LS6 for the caddy?? come on. I'm not saying I would be happy with my $70K (cdn) caddy making the same horsepower at thr real wheels as my $40K SS.
