200mph ls7 cts
200mph ls7 cts
New member here, currently working on a standing mile/hillclimb/time attack car. Started with a 2004 CTS with a melted V6. I purchased a LS7 block and crank, LS3 heads and induction, and a T56 transaxle from a 2006 Z06 vette (this is the triple synchro/one piece countershaft with factory mechanical oil pump to run external cooler version of T56) and am converting to run behind the engine with almost all factory transaxle pieces other then billet tailhousing and Turbo 350 slip yoke.
I build racecars for a living, and am hoping to have a street legal 200 MPH CTS(7)?. I have plans on fabricating tube front end/core support, radiator and cooling ducts, tucked 6 point 4130 rollcage, and taking LOTS of weight out of the car. Hoping to be around 600 WHP and 3000# wet once i have gutted and removed much weight as possible, while still having basic interior and back seat. I will probably be using a stand alone ECU and making a harness... still trying to figure out easiest way to tie into factory chassis harness. One thought is to mount an Ipad where gauges would go and use virtual gauge display from EFILive or HP Tuners to see engine vitals. I know there will be plenty more work to be done like rear diff/links and brakes etc. once i start breaking things with 600HP engine.
Engine is mounted on .250" 6061 plate, with all other powertrain mounts being 6061 1.5" tubing. Plate and mounts are still in process and need to be trimmed to fit. Working on custom oil pan, torsion tube swaybar, and fabricated core support at the moment.
This is a front end i built for a rallycross car that i crewed for,i plan to model mine from.
Glad to see you made it over to LS1 as well. Should be alot more help engine wise here than on CF. Although both are great and have their strengths.
Glad the project is coming along nicely!
Yea, i'm glad someone else said it. Thanks alot i know this site is supposed to be alot better.
I plan on using most of it with a few mods. Coilovers will most likely be custom penskee, or whatever double adjustable piece i can get a good deal on and make fit the chassis. Front suspension on these cars is great, just need to ditch bushings in control arms for weld in bearings, and fabricate tie rods. It's all really nice cast aluminum arms, rack and subframe are solid mounted from the factory. Rear suspension is a bit lame, but my small budget will limit what I can do immediately. Plans are independent 9" housing and some solid links to stop wheel hop.... and maybe someday convert to double a arm in the rear to match the front. Unfortunately suspension in general is a bit slim on funding for the short term.
If you made tubular a-arms for this swap (or even stock replacements) they would sell well! As our stock parts wear out, we will be looking for good boltin alternatives, especially if it offers a solid performance bonus!
I haven't tried but apparently the stock ball joints aren't serviceable so there will be a lot of control arms being sold in the future and we don't have many options.
The steering knuckle for the 08 and up cts is made of aluminum and is considerably lighter than the cast iron parts found on your car. The geometry for those is close but minor frame mods or tubular a-arms will be needed to get it aligned right. Fuzzylogic and Naf have done this but details are sketchy.
If you made tubular a-arms for this swap (or even stock replacements) they would sell well! As our stick parts west out, we will be looking for good boltin alternatives, especially if it offers a solid performance bonus!
I was hoping to eventually check out the entire 08 and up front suspension as a swap but I haven't needed to go that far just yet.
Help us...
Ps....iirc, the v2 hubs are a direct swap I believe for the smaller hubs you have. If those aren't, I believe certain Camaro or vette hubs are but you have options...
