Traction control and Rear/Front tire size difference?
Most people that replace their tires every 1-3 years are impressed by the same or lesser tire, due to the fact that the rubber is fresh. That's why *most* user reviews are inherently untrustworthy.
They're garbage and they didn't do any research to discover that fact. For another $15 per tire you can get Hankook Ventus V12 evo2, which performs significantly better in the dry and the wet. Plus, it's quiet and it tends to meet expectations regarding treadwear rating.
Tires have a short shelf life due to things like oil evaporation, oxidation (a reaction with the air), and accelerated deterioration due to UV exposure and temperatures outside their design basis. Unless you're burning through a few sets of tires per year (or swapping between tires mounted on multiple sets of wheels), you can't really make objective comparisons because your memory of the tires is tainted by multiple factors:
Treadwear
Rubber age
Pavement conditions
Temperature differences
Changes in driving behavior
That's why it's better to rely on tests performed by Consumer Reports and Car & Driver. For what it's worth, I don't credit myself with having perspective on tires either--I don't have enough track days under my belt, and I don't go through tires fast enough. I'm on my 6th set of tires after six years of ownership (4 sets of summer tires, 2 sets of wintery all seasons).
As drivers, we can look at a few things that are meaningful:
Mileage
Speed of wear
Evenness of wear
Cornering speeds (same corner, similar conditions)
Confidence (cornering, wet, dry, braking, etc)
Certainly, it's all got to be taken with a shaker of salt and all the caveats listed above do apply but there are indicators and demonstratives we can draw lessons from, even if they're not perfectly and scientifically objective.
Mileage
Speed of wear
Evenness of wear
#33
I have a set sitting in the basement on my 3/4 set of LC Veneto wheels; since the 4th wheel broke , I only got a couple/few weeks on the tires. That included a session at Watkins Glen; not much to say about that, as I was taking it pretty easy (running the street tires rather than R-comps since it was in the upper 30s first thing in the morning). I'm also going to buy a set for my Subaru, just need to paint the set of wheels they're going to go on.
While I've pretty much always stuck to the bigger "name brand" tires, I've never been one to spend big money on the top dog street tires. Just doesn't seem worth paying the extra 20-40% cost premium to get me additional performance potential that I'll never need. Pretty much any modern performance tire has high enough capabilities that extracting their full potential on the street would involve doing abundantly stupid things.
