TPMS fix/replace/remove
First I have two that are 'stuck' on a certain psi or range - one reads 39 psi almost constantly (occasionally up to 40), the other reads 26-27 psi constantly and over the winter blanked out to --- a few times.
Doesn't matter what pressure I run in them.
Can they be rebuilt/fixed, or do they have to be replaced?
Or should I just have all 4 pulled and call it good?
I did 2 sets of TPMS sensors last year for a couple sets of wheels. I got the first set from Luke @ Lindsay, because I needed them immediately (I'm local, so no shipping delay if he's got stuff in stock). Then I learned that the OEM sensors are Schrader 20116, which you can find cheaper than OEM online - I picked up a set of those on Amazon back in the fall.
I know at least one of my tires is out of balance (I can see where I lost the weight), and I've had vibrations since they were put on - not bad, but currently feels worse. I do need to check wheel bearings and tie rods I guess.
