GTO frcīs on LS6
GTO frcīs on LS6
Hey fellas!
Who has done or tried to get the ī04-ī06 GTO fuel rail covers matching to the LS6 engine?
The only thing i found was a old thread in cf, but there they talked about trimming and grinding the covers, but not where they cut, they used the oem LS6 fuel rails and no coil relocation brackets, what is needed in my opinion, here to look:
http://www.cadillacforums.com/forums...uel-rails.html
Greetz
Ron
Greetz
Ron
I bought a couple of sets of GTO covers, but never did get to this project. I think the black and silver setup looks outstanding. I recall someone saying that the GTO covers rub on some fuel system part and could possible cause a fuel system leak, so be careful, and check the fit closely.
Now checked if they match on the valve covers, but have to set the coil bracket around 15mm higher to the intake manifold to get access to the lower mounting studs and the same closer, think i didnīt need the LS2 fuel rails but a other fuel lining will be needed and if the fuel pulse damper could stay on his place...
Greetz
Ron
Greetz
Ron
