Interior Protectants - 3-Way Shootout (Mothers, Blackfire, and 303 Aerospace)
Today, I found time to do a 3-way shootout between Mother's VLR, Blackfire Interior Protectant, and 303 Aerospace Protectant. I didn't take pictures because it's hard to photograph the differences. The camera angles and lighting have to be just right to pick up smudges, dryness, or greasiness that can be seen in person.
To cut to the punchline, 303 Aerospace Protectant won hands down. It's not surprising since it's had overwhelmingly positive reviews on the detailing forums, /r/detailing, and podcasts I subscribe to. For the test, I divided my dashboard into three sections and applied one product to each. Beforehand, I cleaned the dashboard with Chemical Guys InnerClean (a worthwhile cleaner) to make sure there weren't any leftover oils to mess with my results.
Protip: when cleaning and conditioning the interior panels, spray your product directly on a low or medium GSM microfiber towel and scrub in circles. You're not doing any good scrubbing in straight lines due to the texture of the doors and dashboard. While lower GSM microfiber towels are better for scrubbing and cleaning, I highly recommend a super high GSM towel for the protectant pass to get into the holes and crevices in the air conditioning vents and between the buttons on the center console.
- VLR met the doctor's motto of "first do no harm." VLR wipes off leaving no trace of improvement beyond dust removal. Given that, it's probably no better than a mixture of water and isopropyl alcohol (IPA), minus the drying effect. Still, I've probably burned through 5 bottles of VLR, because it provides UV protection and because, before Amazon Prime, it was easy to pick up at the store.
- Interior Protectant seemed like a good second option, since Blackfire's other main product--Wet Diamond sealant--is considered a cost-effective alternative to expensive sealants like Cquartz. Unfortunately, Interior Protectant was super greasy--even after wiping it down and letting it dry I was still finding streaks and uneven patches of color that had to be corrected.
- 303 Aerospace Protectant provided the best results with the least effort. It finished quickly with no splotches or streaks. It buffed out with a faint gloss that brought out the depth of the interior panels without leaving them greasy or wet. The protective coating appeared to be durable. After it dried, I went for a drive and gotta say--it looks nice. The only caveat is that you need to follow the instructions on the bottle--mainly, don't apply a ton and make sure to buff it before it dries. I sprayed a ton on one panel to see what would happen if I used too much. The result was a film similar to Blackfire Interior Protectant that had to be cleaned off.
