The ultimate solution to the CTS-V1 shifter and transmission issues - Magnum XL Swap
The MagXL is by far the most cost effective way to get a proper shifter and a much stronger transmission in the process.
Not only that the longer tailshaft requires a shorter driveshaft which increases the critical speed for a given driveshaft diameter and material construction. This reduces the cost and complexity of building a driveshaft that can support 200 mph.
It's about a thousand dollars cheaper to build a car with an extra 11" of driveshaft and rubber/nylon bushings than a full-length tailshaft and Delrin isolated shifter stalk. The linkage bushings only have to be tight for as long as it takes you to drive the car off the lot. There's no warranty coverage for "subjective" performance characteristics like linkage play.
#32
dam fine work. a long time ago i started a t56 mag sawp in my v1 but the XL wasnt out yet. i endded up giving up and going to a 4l80e auto instead
good to see that someone did the complete swap
#33
Thanks, I got a few thousand miles on it so far with zero issues. It shifts like a dream and has zero play in the shifter. Transmission mount is holding up great and zero vibrations coming from the drive line even at 120+ mph.
As for the transmission mount being at a angle there has been zero issues with it. Come to find out in the mid 80's the transmission mount on the Camaros was at a 17 degree angle from the factory.
I was talking to one of the tech guys at modern driveline about modifying the tail housing to make the transmission mount flange flat and he told me that its not a issue and won't cause any adverse effects. That is when he told me about the 80's camaro, he did advise me to use a standard rubber transmission mount in which I have yet to do.
The following 2 users liked this post by FD3SLS1:
Alllaaaaaan (06-12-2022), jmilz28 (10-14-2021)
