ACT Twin
ACT Twin
Anyone here running a ACT twin disc setup?
I'm looking at a T1S-G02 setup.
How do you like it? How is the chatter/neutral rattle?
Is it easy to drive in heavy traffic? Strange question I know but some are better than others.
What slave did you use? Monster billet bearing?
Longevity of the setup?
Basically any feedback before I buy it?
-Byron
-Byron
I'm fairly certain that's the model number I used to run on mine; I have it sitting in my basement, will try to remember to take a look after work today. I ran it with an LS7 slave, but killed 2 of those in something like 10k miles, so in hindsight my dimensional stack-up probably wasn't quite right. [As an aside, I wasn't aware of that Monster billet bearing support. Both of my LS7 slaves died because the plastic factory part disintegrated. Wish I had known there was an upgrade available.]
I had no complaints about the ACT. However, after the 2nd LS7 slave failure, a shop convinced me to do an RPS/Tilton slave, as they had had success with that setup on Camaros and Vettes. I was apparently the first CTS-V that RPS did, and they insisted I had to go to an RPS clutch, so out came the ACT. I much preferred the ACT to the RPS, and whenever my transmission comes out, I plan to put the ACT back in.
I don't know if I'm deaf or what, but I've had 3 different twin disk setups (Fidanza, ACT, and RPS) and have never heard any chatter or neutral rattle. Maybe I just don't know what I'm supposed to be listening for? My recollection is that the ACT had lighter pedal effort than the RPS, and it was easier to modulate; that's my main complaint with the RPS - firm pedal and aggressive clutch makes it difficult to get rolling smoothly. That wasn't the case with the ACT.
Did some research. I have screenshot the difference between the -05 and -02.
The reason you probably kept killing ls7 slave is because it's designed to work with the oem plus their provided spacer. This may well have been the reason.
If running the -05 it's a slightly heavier flywheel and rotating assessmbley and a slightly different shim arrangement. The -02 is specifically designed for our car, however both will work ok. Run a ls7 slave with the -05 and life is good. Run a OEM (C6?) Slave with the -02 plus their spacer. I'm going this route plus a billet bearing.
I'm going to go to with the G-02 setup and save a few lbs and have one specific to the car/trans.
I may run Jayson's tilton slave. Not 100% but most likely I'll do the oem slave and maybe swap in the tilton at a later time when I have a bigger budget.
What I do know is that 100% this is the direction I want to go with the ACT twin.
-Byron
Just to update, it's a beautiful clutch setup.
I ended up getting the T1S-G02 kit.
I ran the tilton bearing and had issues. Dropped the trans and set it up a second time and it started pissing fluid. It was a ton of various hydraulic Gremlins, so I ditched the willwood master and the tilton bearing.
For the record I have nothing bad to say about either of the items. Just didn't play well with my car, myself or my new clutch setup.
Switched to centric stock master and centric stock V slave and used the included spacer.
After several thousand miles this thing has become a absolute joy to drive, even in heavy traffic.
If you are looking for a twin, this is a really good kit. My car now drives like I feel it should, is predictable and repeatable and revs really fast with the lighter rotating mass.
It will hold way more power than I will ever throw at it, and the daily 1 hr plus commute is a hell of a lot less annoying.
-Byron
-Byron
-Byron
-Byron
