05 v bown motor
05 v bown motor
I bought a 05 high miles car with blown motor, I have the option of a 5.3 iron block fresh rebuild with a night fury 619 lift cam 862 heads, or a 02 ls1 stock with 80k miles both about same price, plan on putting cam in the ls1 and i have a set of kooks long tubes and x pipe to install also,whats the better motor choice,thanks
Blown motor how? As you said, depending on what's wrong with it, you may be able to rebuild the LS6, which would probably be your best option. Next best would be the LS6's 243 heads (assuming they're OK) on the LS1 block. I'd want the lighter weight and larger displacement of the LS1 vs the iron 5.3, but that's just me.
So many directions you can go. If you want to eventually boost, I'd say go 5.3. Keep in mind, moving to an iron block will require different mounts since the mounting holes are not the same on the aluminum vs. iron blocks. If you're just planning on driving around for a daily, I'd probably put the LS1 in and just have it freshened up to make sure there isn't any sort of underlying problem.
