Terminator X Max Piggyback
Ask and you shall receive!
LS1/6 to LS2/3 adapter harness with breakout harness containing TPS 1 and TPS 2 for the TermX TB connector to plug into. Also made a connector and harness for the TermX pedal connector that ties into the V1 TAC module at APP 1 and APP 2. Revised my plan so the stock gas pedal is going back in to use stock TAC module with TPS and APP signal going to TermX with only 2 cut wires
The following users liked this post:
jmilz28 (02-01-2021)
I was gonna ask since you originally got away from the stock tac module how you had planned to make your cruise control work.
Yea I saw the error in my ways. Waiting for exhaust work now because the o2 sensor is too close to the end of the collector on the headers, reading lean and flooding the engine with fuel. Hopefully sometime this week it'll be done and I can test out cruise control. No CEL's though so that's a step in the right direction!
Tapped into APP 1 and 2 at the TAC and made a breakout harness for the holley to plug into
Harness from LS6 TB harness to LS3 TB with breakout harness for holley. Voltages between the V1 and V2 “holley pedal” are way off and it gave me some problems to I went back to strictly holley DBW harness with holley pedal
IAT sensor placement in stock box
Back side of box
In the car
4” intake tube
ECU mounted in the glove box cubby
Splitter tucked with the second plug hanging out for the USB
Possible placement of the 3.5” screen
jmilz28 (03-04-2021)
Fuel pressure issues
What did you do for fuel pump wiring. I left the stock for now but it does a couple seconds after starting. Tried to copy your build to a t so far. And what did you disable from the factory ecu I have HP tuners also. Any help will be rewarded if possible thank you.
scott
scott
scott
scott
