ABS and TC light / wheel speed sensor HARNESS
Hey guys,
2004 Cadillac cts v:
LF wheel speed sensor code active
i replaced the front left hub after finding the speed wasn’t registering on my scanner. It would intermittently pop up, but then disappear leading to dash lights.
there was corrosion in the connector. I cut and replaced but found corrosion up the wiring harness. My schematic shows the abs module as my next stop.
do you have to remove the radiator to get to it? If I find corrosion has anyone successfully cleaned the connectors or am I looking at a swap?
