exedy twin disc
exedy twin disc
Ust Ordered The Exedy Twin Disc Clutch/flywheel From Mmy Performance Shop. This Kit Does Not Directly Fit. A Adapter Has To Be Machined For A Direct Fit And Seeing No One Makes This Adapter My Performance Shop Is Machining On. That Is A Kick *** Clutch/flywheel Combo. It Is $1800 U.s. But Worth It
i don't know how different this clutch is form the EVO 8 model, but you can get an EVO 8 twin disc for about 1250.....i had a cusco twin carbon clutch(which is better than the exedy) for 1400 in my evo. the scary thing for me is that 1800 sounds about what the retail is for a twin disk exedy on an evo 8. please tell me you did not pay 1800 for a clutch you could have got for 1250!!?!?!?
like i said, i don't know the difference btwn the evo's and the V's clutches (bigger in the V?, harder pressure plate?), but it must be astonishing for 1800 large.
Call KATECH...they have your adapter.
I just tried to install a mcleod on a cts-V....it didn't work,...nor did I get any help from them.
I ended up takeing out the entire unit, again,....and installed a GTO clutch, and flywheel. Plus, the KATECH adapter.
Have fun,..I hope it works out for you man.
