CTS-V with ATI ProCharger D-1SC
#42
"only 6 lbs..." You sound like a true boost-head!!!!
THat awesome , i cant wait for my procharger...maybe a d1-sc just to have some fun...
A leak? huh? Im sure you have looked over all of the plumbing and retightened all of the clamps. You could check for a leak in the boost gauge line if you have on or amaybe some of the lumbing connecting to the motor. As she shifts around on the mounts, the clamps might bulge a bit loose and cause a leak. Could be the bypass valve.
Good Luck, get that forged bottom, drop the CR and let see 12-15lbs...ONe bar? no that is normal boost perssure...unless you already have a bar and want two or three or mabe four!!!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#43
Also check the PCV valve...I had this same issue on my stang, turned out to be the PCV, even though it jiggled like it should. Seems to happen more often than not. I had to plug off the PCV and run open breathers on the valve covers, no problems after that.
#47
#48
hey, mark...when you get a chance, can you get a vid of your car idling? That would be cool!!!!
MAybe that is what i need to get off my *** and man up, and spend the few bucks necesary to get a procharger!!! GOD, i want one!!
#49
Mark
#50
I heard the D-1's are annoyingly loud. This true? I want something "In your face" loud but not something that's gonna sound crappy... heard it sounds like broken bearings rattling around in the engine bay.... I've heard a P-1 and it sounded SwEET!
#51
Ok gentlemen. The video is up in that section of the forum. Not the best quality, but will give you an idea of how it sounds. Hope you all like it.
Mark
Or not....
don't know why it hasn't posted yet. If it doesn't post, I retry again tomorrow.
Mark
Or not....
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#52
my email is arg_z28@yahoo.com
Lets see if the vid is up. Its here in the ls1tech hosting section right?
#53
#54
The regular D-1 does not have the helical cut gears like the SC versions do. This makes a MUCH louder operation, usually louder than the exhaust at idle. It also is not self contained...which is no fun IMO. The D1 will spin up to 65k, the D-1SC can do 62k. For street cars, the SCs are the only way to go, especially with our Vs being sleepers already.
#55
it would be cool if you could enclose the sc with a lid, so you can really be completey silent and incognito...buuhahahaha!!!
OH, how about one of those cool switches that mad max had on his stang. Hit the switch and blamo, the blower turns off...oh, blamo.its back on again!!
That would rock!!
Sorry guys, im not beeing all that serious tonight, just trolling around....
That would rock!!
#57
omg!! please!! that would be SO cool!
I saw the idling vid and though it was great, the sound was a bit baised. Umm, more high to mid range with tons of distortion in the sound. Im sure it sounds way better in person. You can never get a quality sound unless you get a good mic for vid.
Anyways, only 6lbs huh? does the car have a cog belt system? Maybe your getting some belt slippeage and not spinning that blower all the way? Could be a leak somewhere or the BOV isnt properly adjusted and is constantly bleeding though vey minimal. Im not sure....but i know you guys can figure it out.
Good luck on that Bob, im sure its nothing and he'll get bored of the 8lbs and move it up to 12, 13...MAaaaaybe 14ish ...hmm....But knowing our cars, still turning 12'z!!!! (J/K, no pun intent, just keeping it lite!)
#58
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Mark
#59
oh, no worries mang!! The video wasnt thjat bad actually, i ws just making a few comments!!! It very much appreciated...
Hmm, a 8 rid belt system.... Well, it shouldnt be a belt slipping but you never know, stranger things have happened when it comes to motors.
I believe that the numbers your puting down re accurate, but with a increase or derease in pulley size, which shold net you more power you are staying right around the same so SOMETHING is up.
THe bov could be a problem but you said you checked that. This is a SC unit correct? Im just think that in theory there is something not allowing that unit to spin fast enough to get a higher level of boost or it is spinning and slippage, which i've have seen tons of.
good luck, im sure you'll get this thing running nice.
#60
Mark
