CTS-V oil pan dimensions
Say, can anybody get the measurements of a CTS-V oil pan? I need to know how long the flat part of the oil pan is... the part that's very shallow. If anyone can measure this, I'd appreciate it! The shallow part will prob be mostly covered by the front crossmember. It should be somewhere around 10 or 11 inches.
Thanks!! -Dave
Thanks!! -Dave
Yea, that's it... basically I want to know how "deep" the sump is... which I think means how far back the deeper part of the oil pan is. It's tough to explain because I am using the word deep to describe two different things. A deep sump is very far back on the engine.... but the sump is also pretty much the deepest part of the pan, where the most oil can accumulate for pickup by the engine.
![](http://www.geocities.com/zeemr@sbcglobal.net/Voilpan.jpg)
All measurements are approx... lot of stuff in the way to try to get an accurate measurement:
(1) Shallow Part: 11"
(2) Deep Part: 9 3/4"
(3) Widest point: 9 1/8"
(4) Depth (of pan, not including block): 1"
(5) Depth: 2"
(6) Depth: 3"
(7) Depth: 6 3/4"
