Engine running rough
Hello. This is my first time posting. I have an 04 V with 31K miles. I don't trash it, but drive spirited every once in a while. I recently noticed that it is running extremely rough at idle, but when I took it into the dealer, they said that is normal for this engine. There were no codes, but I've had this car long enough to know that it is not running like it used to. Has anybody else had this problem? Thanks.
Originally Posted by pz87fm
It does feel rougher when I turn it off, definitely. I'll check that out, thanks.
We've replace many mounts.
However, if the car is new to you...the LS6 camshafts have been known to be confused with a "engine roughness" at idle. Atleast, we saw that with some early customers,...or someone new to the Ls6 world.
The other fella's are right though,....bring it to the dealer,...with your concern. The first thing they SHOULD check, is the mounts.
I just replaced both motor mounts on a blown V. What a bitch that was.
