Short throw shifter installation questions
Is there a write anywhere with someone doing from the top. The write up I found had you dropping the exhaust and basically making a lot of extra work for yourself. Also, a b&m with uuc bushings will i need to put some dynamat in there to keep the noise down or will this set up be nearly as quiet as stock?
The B&M shifter I bought came with a instruction manual with everything done from the top. When I first read through it I was kinda scared of drilling out the revits but with the right size bit youll be fine. I dident use any dynomat and the noise is very, very limited, my wife couldent notice it with the radio off and widows up until I pointed it out. But like I said before if you install the UUC bushings beavel the leading edge youll understand what I mean once you get in thier and see the old bushings.
This link is a search that i use it pretty much pics up all the cts-v parts that are on ebay
http://search.ebay.com/cts-v-ctsv_eB...a21QQversionZ2
you can also try ebay express since ive noticed them on there to
I just purchased the B&M shifter, could someone give me some contact information for where I could find the UUC bushings? (and maybe soem detail of exactly what they are? different mateial etc?)
Thanks in advance!
Mike
Thanks in advance!
Mike
#32
too high go to the faq sticky at the top of this forum and then to vendor list. You are looking for lindsay cadillac and I believe the bushings are urethane where the stock are rubber. Basically harder bushing = firmer, smoother shift. Also, i think they run about $40
