White Z06 got spanked.....
Originally Posted by 2c5s
Obviously he's a moron that has an extra 30k to waste on his Z06. Maybe you should buy one? But then again, they only add 7k to the sticker, but I bet you knew that already, huh.
http://www.chevrolet.com/corvette/
All I'm saying is that if this guy "raced" the C6 Z06, the driver of the C6Z must have been learning to drive stick, no matter how much power the V had. It still weighs 4000+lbs with driver.
C6Z - 3150 lbs/435 rwhp = 7.24 lb/hp
CTS-V - 3850 lbs/540 rwhp = 7.13 lb/hp
Add a driver of equal weight and the lb/hp advantage goes to the V. Obviously, if the V had more hp, the advantage would be greater.
I'll try to get you a video in the next few weeks to address your doubts of a high hp V.
on the subject of power to weight..how are you guys cutting weight on your Vs? Hood? Wheels? Its just killing me how these Vs are not running the 1/4s they should for the Rwhp they have...
A CTS-V is not set up for the track...at all. I don't think anyone with a built rear has posted an ET yet. We're all six-speed cars, which isn't the best at the track. You can't put smaller than 18" rims on the rear, so you are limited on traction even if the rear was built to hold it. It's just not a good drag car.
I'm sure that if someone threw together a high hp V with a built rear end, big stall automatic and some tires that could hook it, we'd see better ETs.
I've got an F-body for the track. The V is for the street, but I understand your point.
Originally Posted by MCasano1
Well, that would be a silly position to take. If you have a V putting down 540 rwhp and a stock C6Z putting down 435 rwhp, is there not some point where horsepower overcomes weight?
Originally Posted by mbrownin
Well, of course there is a point where the V will have the advantage. Maybe some of the opinions here are based on the OP's sig. which indicates a V with 497 rwhp. If that's accurate, then the hp/weight advantage goes to the C6Z06.
