Bushing issues - wear and noise???
Anybody having the same suspension bushing issues I am with noise and wear? Also, how about your motor and trans mounts? Every 3-4 months I have these suspension creaks that are annoying and embarassing - especially if I have customers in the car.
Thanks.
Thanks.
I'm on my thrid set of motor mounts at 62K miles. I haven;t had to change my tranny mount yest (although I did get a new tranny at 42k miles, so it may have been swapped out them). UUC Motorwerks is supposed to have poly/high durometer Engine and Tranny mounts out by the end of Dec. Defintaly look into those.
Hopefully UUC will also finish up the front differential bushing they are working on. That will help significantly with the 'clunk'.
Good luck.
-Chris
Thanks Chris.
What is a TSB bushing? Is this the manufacturer?
I had my '05 V in today at the dealer where they lubed the bushings (again for the 3rd time in 31K miles) and replaced another engine mount.
Thanks for the info on alternative mounts the next time I need a repair. It seems that my engine mounts only last me between 10 to 15 K miles.
Thanks Chris.
I would go to your dealer, and ask them if you have the 'TSB Bushings'. If so, have them removed for excessive noise, and don't look back.
Take a look on the FAQ (www.cadillacfaq.com) for info on the actual TSB to reference to your dealer.
Good luck.
-Chris
