Probably and old question; CTS-V front window trim issue
Anyone else have a problem with the front window trim coming off, often.
I have had it replaced several times; and more importantly, if you have this problem have you fixed it.
Thanks
Thanks
vj, go to a quality auto glass company in your area. Explain the issue you've had and they should be able to fix you up with little time and little expense. I'm curious if your upper reveal molding has been altered providing the bad fit or if you've had the windshield replaced. Anyway, pick a good quality shop and they should be able to help you with a resolve.
