Harris Speed Works 78mm LS6 CTS-V Wet Plate Kit and Microedge + Upgrade CHEAP!!!
Putting together a new nitrous setup, so the old stuff (and some new stuff!) has to go. All prices are pretty firm but if you think I am overcharging PM me a REASONABLE offer. All prices include shipping! Parts shipped out next day via 2 day priority mail!!
Package Deal!:
Harris Speed Works Plate, Solenoids, Purge, and Lines $215 Shipped
Harris Speed Works HSW 78mm Plate w/all hardware and 100/125 jetting (used) $110 Shipped.:
As you can see the threads on the nitrous inlet are a little bit messed up, but the jet seats perfectly and the lines thread on perfectly. Performance is not affected. I used the plate like this all last season. The fiting is $12 from HSW if you would like to change it.:
Harris Speed Works HSW PowerMax 3 Port Bottom Outlet Nitrous Solenoid w/fittings and bracket (used) $65 Shipped.
Fresh rebuild with new coil from HSW never installed since rebuild, tested good.
Harris Speed Works HSW PowerMax 2 Port Bottom Outlet Fuel Solenoid w/fittings (used) $45 Shipped.
Tested good.
Harris Speed Works HSW Nitrous Purge for PowerMax 3 Port Solenoid w/fittings (used) $45 Shipped.
Needs new compression ferrule if you will be using the compression fitting.
Harris Speed Works HSW ~20" Nitrous Solenoid-Plate and Fuel Rail-Solenoid/Solenoid-plate (used) $25 Shipped.
Harris Speed Works HSW Microedge + Solenoid Driver Box (NEW) $90 Shipped.
Package Deal!:
Tested good.
