Need a New Driveshaft
Busted my drive shaft over the weekend so now I'm looking for a replacement and wanted feedback. I plan on selling my car in the fall so I hate to throw too much cash into it, but also not willing to buy a new OEM one.
I'm thinking either the driveshaft shop 1 piece, one of the GeForce one pieces or GeForce 2 piece.
I know the 1 pieces are limited to 150mph which sucks ***, but I've never gone over 150 anyways so I'm leaning towards them as they are slightly cheaper. I'm also leaning towards the driveshaft shop simply because GeForce has a tendency to take forever and a month to ship their items.
Any thoughts or opinions on these 4?
http://www.driveshaftshop.com/2004-2...um-drive-shaft
http://www.shop.gforce1320.com/produ...&categoryId=61
Hmm decisions, decisions...
Then pick up a 3.31 differential and up the limit to 169 mph. I've done 160+ mph in 5th and the car still has plenty of legs. If 54 and Gulf complete their 8.8 project, I'm almost certain that I'll be in the market for a carbon fiber driveshaft.
You know the 150mph limit is a round about number, if you were to give me your rear ratio and how tall the rear tires are we could get a exact number with a safe factor most are higher, were workingng with both a 8.8 and a 9" diff kit set that we have made CV adaptersrs for both ends, this will make the tube section much shorter and raise the Critical speed to a much higher number. keep and eye out for them soon. they will be similar to the 2009+ carbon we make in both the aluminum and 3.25 Carbon.
Most popular 8.8" final drive ratio for this car is 3.55, but it's an expensive (and therefore rare) modification.
http://www.cadillacforums.com/forums...shaft-dss.html
Please note that we're still concerned about the heat from the exhaust getting to the carbon fiber driveshaft. You should really pay attention to Junior1--he's on the bleeding edge of N/A track performance on his heavily modified CTS-V (he's at 3366 lbs too, due to massive weight reduction efforts).
I am running stock sized tires.
This is your original announcement thread:
That being said the shaft would have a .91 safe factor due to the level of balancece, CV joint the U-joint not moving at a large angle. so with the 3:73 gear it would be 6335rpm, or about 138mph.
with the 3:55 gear is would be @ the 150mph mark. The carbon shaft would have a safe factor of about 220mph (or more) on the 9" and the 8.8 kits the dimension is different and the ends longer so these numbers would be a bit higher.
this is balancer at work
Frank is building a new 1 piece with 2 cvs for me now. I am torn about the critical speed, but the shaft will clear any shifter no problem from measurements. I may consider the Carbon Fiber and wrap my exhaust, but I am only street use so kind of hard to justify the extra cost. Sure is a great guy to deal with.
Definitely consider something with a CV in it, like the DSS 2 piece or his sson to be new 1 piece double CV. Should help avoid vibrations.
Consider this, why did cadillac put two cvs in the car? and on the new ones? To stop driveline vibration I would bet.
My actual shaft length is really only about 50" instead of the 60"+ gap for the driveshaft. 10" shorter definitely helps the critical speed, but Frank is the math guy and can explain much better than I could right now (still learnin
