Best price on a 12-bolt (ONT) ?
Did you see his 60ft time?
It is a M6 and is leaving very hard, my 1.47 was a wild ride, I can not imagine a 1.39. That is like going 0-60 in less than 2 secs. Much higher than 3-4k. I was leaving at at 6500 and dead hooking for my time NA.
He can clarify, but I think that was on a 200 shot with his 402.
My 12 bolt would not likley take that though. I broke my Eaton HD at an autocross.
Yes it is a 6 spd car still......yes on straight motor i am leaving around 5000-5500 and on the spray i leave around 4000-4500 and yes it was a 200 hit when i went 9's. the tire was a 27" hoosier QTP. Also full weight w/ac and a molly cage
I must be lucky with a TruTrac in my 9" as well. I've done quite a few high RPM launches on both 26x10.0 and 28x10.5 ET Drag's cutting anywhere from 1.49-1.55 60's. I've just got the 31 spline axles and now it's in my Camaro with a little over 500rwhp NA. It'll get hit with a small 100 shot pretty soon. If/when it breaks I'll probable put a spool in it and keep the 31 splines til an axle breaks. It'd be pretty hard to twist a 31 spline axle though I would think.
