Need to pass E-test..
Gonna be moving to Ontario, so I'll have to get my 1998 chev 1500 4x4 E-tested. Thing I'm worried about is while its in good mechanical shape the engine is a 383 stroker, comp full roller valve train including 1.6 ratio rockers & duel springs,Cam, heads redone and moded to allow for higher lift, bbk 80mm throttlebody,dual fuel nelson tune, intake, headers, true dual exhaust(will need to put Cats back on it) 70,xxx on the engine. So If I throw the Cats back on the truck would I have a chance of passing or am i screwed? Is there any tips and tricks to passing?
I'm in Manitoba, so passing E-test was never a concern before.
If I tell them its a 383ci will they allow it to pollute a bit more than a 350ci would be allowed??
I believe the ministry does the inspection, so they will look for smog parts, but other than that I have heard it is almost impossible to fail the hotrod test...
It can't really be as easy as saying "I have a bigger engine than stock, test it as a hotrod" can it??
Also what is this "conditional pass" I have read about? Is that only for vehicles getting retested? Or can a first time tested vehicle get a conditional pass?
I dont know if it would affect insurance, I dont think so, because I dont see why the ministry would have a need to contact insurance. Again, thats something you will need to ask though.
A conditional pass is once you have failed the test 3 times I believe, and have spent something like over 500$ to try and have the car "repaired" then you get a conditional pass for the year I believe. The repairs have to be done at a credible shop, so it's not like you can just buy the parts, show a receipt, say you installed it yourself, and then return the parts later...
you will only get the conditional pass if you fail the test 3 times (3 times is the max number you can take the test) its basically there so that people who cant afford to do the work to there vehicles to get it emissions legal arent up ***** creek without a car...(money grab still, because next year you gotta go through the same crap)
and im running high flow cat magnaflow. i fail safety cuz of my exhaust is dump before axle but it got it pass anyway
you want to register under hod rod u need to show them all the reciept
if you dont have reciept for 383ci then they will run test under year 98 350ci
btw what kinna cam u running
conditional pass
u not qualify for it as for the fist time register your vehicl in ON
check out this link
http://www.mto.gov.on.ca/english/dan...rgoutcan.shtml
conditional pass
check out this link
My cam is a 218/224, lobe separation 112 . What did it cost to get your car tuned? My truck has some kinda nelson 87/93 octane tune.
Your car has what, a 350 stock?
Oh, and if my rear 02 sensors are mia or not working will they care?? They just do a sniffer test and take a look to make sure the cats are there and your gas cap is good right?
Good Luck
If you have a mild cam and can tune it a little lean and remove some of the timing at idle, plus pour in a couple bottles of gas line anti freeze you will likely pass.
Make sure the motor is good and hot before the test.
Good Luck
Your car has what, a 350 stock)
i tune it myself stock is 5.7L 350 i guess. i change my engine to lq4 6.0L
just do the same as Rampant said If you have a mild cam and can tune it a little lean and remove some of the timing at idle, plus pour in a couple bottles of gas line anti freeze you will likely pass.i do the same as Rampant tune it a little lean
but i dont trust gas anti freeze, just throw cat on give it a try see how is goes and see what need to be done then u can figure that out now it just shoot in the dark
I see their going to "on-board diagnostic inspections" in the next yr or 2 for '98 and up. Will that make it easier or harder for us to pass?
I think they support most GM vehicles so you should be alright, I would check into it though.
another trick I did with my car is, bump your idle speed to as close to 1200rpm as you can without the car going over...this will allow your idle to burn cleaner.
Actually, the place that did my emissions didn't orignally want to do it because my idle "appeared" to be over 1500rpm...it wasnt until I put my laptop on it and showed him my scans that he said ok...but he was scratching his head at why I had a laptop that hooked up to my car
...I told him I was an aspiring mechanic lol...(pure b.s)edit: I don't know how much of a difference the LSA makes for you V8 guys, but my cam spec that I passed with was 210/220 .512/.512 (gross lift) on a 112 LSA
she passed in every category with flying colours except one...I cant remember which one, but she just squeaked by if I remember correctly...but it was all on the first try anyways....
and i use hp tuners i just have mine done last month so no onboard yet, if not take it to Champion Motors have them tune for ya they are sponsor here Good luck
