Quick emissions question
Today I hooked up my code scanner and its says: "Monitors not ready" under the IM status. However, all the monitors that are displayed on the scanner say OK, with exception of EVAP and Cataylist if I recall. On the MOE website it says vehicles between 1998-2000 are allowed to have 2 monitors not ready for a test. So my question is, if if the IM status states that monitors are not ready, should I pass in my scenario since I only have 2 not ready? Or am I missing something?
I know it may seem like a stupid question. I rather make sure I have my info together before I take the test because if I will fail right off the bat for not having monitors ready, I will drive the car more to get the last 2 monitors in the ready position. I want to try and limit my driving because my sticker is already expired (it expires in the winter months, while my car is in storage).
Thanks!
Can I still pass emissions with a PENDING code? Check engine light is not on.
Now, the drive cycle is I think 30km, so your safest bet if you want to drive it is to either hop on the highway if there is one very close by, the odds of you running into a cop doing all highway driving, getting off and getting right back on to go back is slim.
OR
put the car onto jack-stands and run it 30km with the tires in the air.
OR
I called the Ministry and they said they don't test pending codes. They said they're only concerned about codes that are set and have activated the check engine light. This morning I cleared the PCM and within about 10 Km of driving the same code P1153 came back. I am going to drive the car around to get all the monitors to set (with exception of the Catalyst and EVAP). I read that they won't set due to the pending code. But due to my model year I am allowed 2 not to be set.
I posted in newbie tech about O2 sensors, but for us guys here in Canada what are some good options for sensors? Keep in mind that I have LTs and ORY. I was reading that C5 Corvette rear sensors are good for F-Body front O2s? Is this a plug and play situation? NKG sensors are on sale at Part Source and would consider buying one.. I want to try and eliminate this code because its annoying.
Thanks for all the feedback guys, much appreciated.
Also, LT1s maybe be different but the Ls1 front and rear O2s are the same with the exception of the wire length. I have personally swapped O2s and purchased rears for the fronts because of the longer leads because of my headers.
If a 1999 Corvette rear O2 has a long enough wire, I may go with that. Guys seem to praise the Corvette O2 for some reason.
from what i read this post we can just repin the PCM to get rear O2 work as front so you don't need extension im planing just delete it running open loop all the way
I think I'm going to get a NGK 99' Corvette post cat O2 sensor. I just hope the wire is long enough.
https://ls1tech.com/forums/generatio...vette-o2s.html
it really easy can't go wrong with that but keep me posted with NGK
i don't know if anyone in this forum done this but i drill 2 hole one on each side
so far putting sensor back in no code havn't come up i didnt even have to clear my code i double check with my scanner both sensors switching fast back to normal ill put more miles on it see what happen
