2015 1LE+DMS/Jam Cam=12.5@116 on Goodyears!
Went to the track on Friday to see what the cam would take off my ET's. Not bad considering the weather-gotta do something with the hi IAT's on this car. 140 + in the staging lanes-hopefully the Apex cold air scoop and RotoFab coolant bottle 2 solve this.
I can see going 118 in the cooler air.
I got a lot to learn as far as driving these cars fast compared to Vettes-the pig *** weight makes them a lot harder to launch-that 60 and riding that clutch is key!
But the ECS kit will probably be on before then.
Bet it felt good to row the gears again! Probably half a second off with a set of drag radials. Back when my car was stick it went 12.15 @ 115 with 410 rwhp and 3760 lbs. Yours is 100 lbs heavier and 60 hp more so there is definately more to be had! No doubt you'll get it figured out!
