Canadian Members We never leave because we have The Beer Store
9" or S60 in Canada?
Old 10-01-2019, 01:35 PM
BigBadWhitey's Avatar
Default 9" or S60 in Canada?
Anyone know of any shops that sell 9inch or s60 packages for F-bodies up here in canada? Been eyeing a 9" for a while but the currency conversion from the states is killing it.
Gladly take any recommendations!
Old 10-06-2019, 07:19 PM
RAMPANT's Avatar
I did a MWC 9 in mine. Yukon thru bolt, Wavetrack and Watts link. Shipped to USA and went and picked it up across the border.
Old 10-12-2019, 01:20 AM
That's what it looks like I'll end up with. Was either looking at a 9" or now an S60 from MWC. Looks like a lot of regular housing 9" end up needing aggressive clearance in the tunnel? Any idea if thats an issue with the s60 also?
Old 10-12-2019, 01:27 AM
SladeX's Avatar
I put a 9inch in mine and had no issues with tunnel clearance. I also put in a MWC watt's link later too.
Old 10-14-2019, 09:37 AM
manzo81maro's Avatar
I went with the S60 through MWC...I had to clearance the tunnel slightly to clear the MWC torque arm bolts/bracket, and also at the MWC double drop crossmember driveshaft loop support.
Other than that, it’s completely bolt in and was about $1000 cheaper than the MWC 9” with similar options.
You take a weight penalty with the S60, but it’s supposed to take less power to turn vs 9” in theory.
Having said all that, if I was starting over, I would have gone with the fabbed 9” for the weight savings and serviceability.
Whichever you go with, make sure you get adjustable LCA’s and PHB to get everything centered.
And definitely cross the border to pick it up if you can...the freight and duties on a rear to your door is stupid.
Cheers,
Alex
Old 05-24-2020, 10:39 PM
fstr n u's Avatar
Moser 12 bolt in mine. Running over 800hp with a rebuilt 6MT and no issues.
Old 02-21-2021, 01:48 PM
trans_am_2000's Avatar
A fellow by the name of cam on here has done 8.8 for members in the past. I was talking to him. And hoping to have hike make a few more and grab one myself. $1000 for the case. Haven't found anything else up here
Quick Reply: 9" or S60 in Canada?
