Modifications and Ontario Emissions...
Originally Posted by SSteveL
Do you think most MOE cops would know that some LS1 F-bodies came from the factory with an EGR and some did not (depending on model year)?
If no emissions equipment is removed, they shouldn't have a problem with a rear mounted turbo
You guys that have had the roadside check done, did they check for O2 sensors? I plan on deleting the rear ones when I put the TSP catted Y on.
Someone asked whether or not the officers would know if your car was originally equipped with an egr valve, the underhood sticker does list it, so the sticker would also have to be removed
Good ask on those rear O2's Rich.. Sounds like a good idea to remove them with HPTuners, then install them in the pipe.
Here's a question, if we do that, can the O2's be installed in the pipe (bungs welded in/holes cut) after we've already installed the pipe on the car or is that something we should do ahead of time? I've got my Y laying around so I could drop it off at a shop Monday and have them throw bungs into each side for the O2's... If it can be done later with the pipes on the car, I'll just wait until later on.
Good call.
I'll probably do that. I know a couple good exhaust guys that will do it no problem. I think it'd be the safest to keep them even if only for looks.
We're gonna have some fast rides in KW this year boys! Seems like all the LS1 guys and even the LT1 guys are stepping up to the plate!
