Canadian Members We never leave because we have The Beer Store
Time to Store the car!
Old Sep 29, 2005 | 01:33 PM
Ouchburns's Avatar
Default Time to Store the car!
Please post your winter car storing techniques!
Old Sep 29, 2005 | 01:57 PM
RAMPANT's Avatar
My storage technique is to:
1 full tank of fuel, plus fuel stabilizer (no room for condensation)
2 fresh oil change
3 thick ergonomic floor mats for the tires (helps stop flat spot of tires)
4 tire pressure to 40psi for the same as above
5 disconnect battery after a trickle charge
6 start the car once a month and idle for 15 minutes
7 repeat step 5.
8 fresh coat of wax and cover with flannel sheets
I think that is about it. I may have forgot a few off the top of my head.
Rampant
Old Sep 29, 2005 | 02:10 PM
BJM's Avatar
BJM
I refuse to help you..........yet. Car storage season for me is December. The top stays down as long as it is +10 or warmer. The car is off the road when the snow flies.
When I do store it, I park it, put in some fuel stabilizer. I run it once a month. I am back on the road in April, sometimes March. Its only idled for about 4 months. This process has worked for 15 years on 3 different cars.
Old Sep 29, 2005 | 02:31 PM
STROKER R/T's Avatar
I NEVER STORE !!! I JUST MOD MORE !!!
Old Sep 29, 2005 | 10:05 PM
Bugblndr's Avatar
I fill up the gas tank and park it in the garage. It gets new oil before or after the winter depending on if I get caught off guard or not. I've had my car back for 8 days now so it'll be a couple of months before I think about parking it.
Old Sep 30, 2005 | 04:58 AM
Patman's Avatar
Store it? No way, I drive mine! I just make sure to get it fully washed by a detail shop every Saturday, and visit the coin wash a few times through the week to keep the salt off the paint as much as I can. My car still looks like new.
Old Sep 30, 2005 | 07:33 AM
Ouchburns's Avatar
Do you put winters on it?
Old Sep 30, 2005 | 08:49 AM
BJM's Avatar
BJM
Toronto area winters are quite a bit milder than Ottawa's. You probably have 25% of the road salt we have here. Its not the paint that matters, especially on a fiberglass car. The steel underneath needs to be cleaned off or encapsulated with oil, tar, etc. I have seen older Corvettes here looking shiny as new and the frame literally fell out in chunks.
Old Oct 1, 2005 | 06:56 AM
Patman's Avatar
Nope. When the snow is too deep I borrow a car or rent one. But in light snow the stock tires work just fine.
Old Oct 1, 2005 | 12:56 PM
Hooper's Avatar
I never understood that logic. To me, it's no big deal to put the car away for 4-5 months. The chassis is not exposed to rust-inducing salt, slippery roads and fender benders are avoided, the peace of mind knowing your car is tucked away safe and last but not least, you have something to look forward to in the spring. Let's face it, Camaros, TAs and Corvettes are summer cars IMO. I don't like driving mine if it's dirty and in the winter that's every day.
Old Oct 1, 2005 | 06:59 PM
Patman's Avatar
To me I don't understand why I should be making car payments on something that's sitting in a garage not being enjoyed. When you look at the wintertime as a whole, there are way more days when the roads are dry than there are with wet or snow covered roads. And as long as you fully wash the car at least once a week, you won't see much rust on the undercarriage, perhaps if you drove it for 20 years in the winter you might, but I will not own this car in 20 years, I'll own a C6 or a C7 by then.
I don't like seeing mine dirty either, but I sure would rather drive it dirty than not drive it at all. JMHO.
Old Oct 1, 2005 | 09:08 PM
Hooper's Avatar
Yes. But if you store it you're going to be able to drive it long after the payments are done. And it will be in pristine condition. Pat, I can see your point. But for me, I like the feeling of knowing it's out of the elements (I don't have a garage) in the winter.
Old Oct 2, 2005 | 08:17 AM
Patman's Avatar
Mine still looks in pristine condition, most people believe it's a 2004 (and those who don't know the Corvette changed body styles think it's a 2005!). I highly doubt too many people will lie on the ground to look at my undercarriage. Last time I was under there changing the oil I didn't see any hint of rust anyways.
Old Oct 2, 2005 | 12:35 PM
BLCKBRD's Avatar
You could also get a oil-spray underneath to protect from rust.
Old Oct 2, 2005 | 07:26 PM
Ghostintheshell's Avatar
2 fresh oil change
7 repeat step 5.
Rampant
I wouldn't advise starting the car at all during the winter. This melts any condensation, and creates more, essentially MAKING more condensation, everytime you start it.
My advise is to not start it until spring.
Old Oct 2, 2005 | 07:38 PM
RAMPANT's Avatar
I do this to keep oil in the wet areas of the motor. Hopefully no surface rust in the bores. I let it warm up for 15 minutes or so. My stock exhaust lasted very well for 6 years and the bores of my stock short block still looked quite good too. But thats just my opinion and experience. It could cause some condensation in the exhaust though.
Rampant
Old Oct 3, 2005 | 09:20 AM
canadian z28's Avatar
I crack the windows down a bit to give the ruubbers some time to expand and air to flow through the interior. I also start it once a week to keep the engine wet and use cheap gas with stabilizer. Basically do the same as rampant except for the floor mat idea. Where do you get those floor mats?
Old Oct 3, 2005 | 10:09 AM
RAMPANT's Avatar
I bought 1 from Costco and cut it into 4. It is about 3/4" thick and very soft, so it will create a curve for the tire to sit in not a flat concrete surface which can distort the cords in the belt.
Rampant
Old Oct 3, 2005 | 02:33 PM
396LT4's Avatar
I have a number of cars that I store in the winter and I have been doing basically what Rampant said for the last 20 years with no problems, except for putting mats underneath the tires. I just pump them up to at least 40 psi and have never had any problems with flat spotting. I would also just wipe down the door and trunk seals with some silicone just to keep them pliable and prevent them from drying and hardening out in the closed position.
Will your storage space be heated? What about humidity? What is the floor surface like?
Old Oct 4, 2005 | 06:33 PM
transamtom's Avatar
Silica bags from shoe boxes keep the interior moisture free.
