CPE 402 Longblock in stock, built & ready to go!
402 LS2 Longblock:
LS2 4.00" Aluminum block
Clearence Block for rods
Bore & Hone w/ Torque plates
Line hone
Knock Sensor Tapping
Eagle 4340 4.00" crank
Lunati Billet 6.125" rods
Wiseco Pistons & pins
Moly rings
Internally balanced 402 rotating assembly
ARP Main studs
H-Series Rods & Main bearings
AFR 225cc CNC'd heads
MLS Cometic Head Gaskets
ARP Head bolts
Custom Comp camshaft
Comp Cams Pushrods
JP Double Chain
Morel lifters
LS2 Lifter Trays
Ported LS6 Oil Pump
Front LS2 Cover w/ Sensor
LS2 Valley Cover w/ gasket
Sheetmetal Valvecovers
Blueprints
$9,500usd
Line hone
Moly rings
ARP Main studs
ARP Head bolts
Comp Cams Pushrods
JP Double Chain
Morel lifters
LS2 Lifter Trays
Ported LS6 Oil Pump
Blueprints
$9,500usd
