Carbed LS1 with front mount dist.
hey, nice build. it looks like you have a bunch of trick parts in it for sure.
so, the intake is drilled for additional bungs. those are for nitrous I am assuming?
are you going to run anything off the crank? like the alternator? where will that be mounted.
nice motor plate pics. thanks
Cost wise i could have went with the 6010 trigger and coil packs for a lot cheaper but this is how i wanted it,if people don't know what a carbed LSX motor is then i will be glad to school them on it,there are a lot of them out there. Also,as far as functioning it has a 4.100 bore and massive ported L92 Heads,Callies internals,and machine work as good as it gets,i will PM you when i come from the track and let you know how it "functions".
#34
ok where back to work on this again, here are a few pics to get us started.
Block is a Ls6 with 4.100 bore
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929101440.jpg)
Crank is a stock stroke callies dragon slayer
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929101504.jpg)
Callies main caps
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929101649.jpg)
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929101637.jpg)
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929101506.jpg)
Piston and rods are Lanuti
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929101751.jpg)
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929102027.jpg)
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929102027a.jpg)
![](http://i46.photobucket.com/albums/f129/LS1Queen/chris%20G-body/0929102028.jpg)
More tonight
Callies main caps
More tonight
