Carb Guys: Anyone grind the injector bosses out of your Victor Jr?
My L92 Vic Jr. carb intake just showed up the other day and overall it looks like a nice piece. But I noticed that the injector bosses that are cast into the outside of the runner also protrude into the inside of the runner. I'm sure for cost reasons Edelbrock just casts the exact same intake for injected and carb applications and then machines out bosses to accept the injector on the injected models, and leaves it fully intact on the carb ones. But for a carb application, it seems like it would be an unnecessary flow restriction and needs to be ground out for optimal flow. Has anyone else done this?
LOL....yeah...I'm definately picky enough....to a fault sometimes. Is there a good place to pick up aluminum specific carbide bits? Is this something Home Depot or Sears would commonly stock? I know I've seen carbide bits at both places but never noticed if they were specifically for aluminum. I have some that I picked up from Harbor freight and I'm not sure they'd grind butter.
Cool tip...thanks! My buddy told me they had some special grease at his work for the same purpose, but I figured there was probably a more commonly available item (like ATF) that may work for the same purpose. I'll give that a try.
OK.....I know this thread is very last year....but I said I'd update it once I got mine done, so here we go.
Here is what I started with:
![](http://i929.photobucket.com/albums/ad137/glcropp/IMG_6890.jpg)
Well, that just won’t do, so I spent some quality time with the Dremel tool this weekend. I started with a carbide bit and stopped frequently to dip it in ATF as recommended earlier in this thread. It worked great! Not only did it keep the bit from plugging up, but it also lubricated it well enough to make it cut smoother. I also finished the ports off a little with a sanding roll, and then some paper by hand. I might not have done the best job on them, but I certainly didn’t make them flow any worse.
![](http://i929.photobucket.com/albums/ad137/glcropp/IMG_6897.jpg)
![](http://i929.photobucket.com/albums/ad137/glcropp/IMG_6898.jpg)
![](http://i929.photobucket.com/albums/ad137/glcropp/IMG_6899.jpg)
![](http://i929.photobucket.com/albums/ad137/glcropp/IMG_6900.jpg)
I’m not sure, but I think something is missing here……..Oh yeah…..a carb. Well, I ordered up a new 4150 from Patrick Prosystems on Monday. It should be here later this week!
![](http://i929.photobucket.com/albums/ad137/glcropp/IMG_6904.jpg)
