Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
engine dieseling when shuting down
Old Sep 26, 2010 | 08:34 PM
1994t/a's Avatar
Default engine dieseling when shuting down
my carbed LS3 has wants to diesel when i turn it off from driving it sometimes.only does it when i drive it for more than 10 miles straight without shuting the engine off.its not real bad dieseling just does it for a second maybe two.gets on my nerves though...any ideas?it has the GMPP intake on it with a 750 edelbrock.im not running any timing advance with the MAP sensor but i got the base timing at idle set at 9* right now ramping up to 31* at 2500rpm.think i need more timing at idle or put advance in it at idle?main reason i havent messed with the advance is im not used to the whole psi thing.
thanks for any help
Old Sep 26, 2010 | 10:28 PM
3pedals's Avatar
deiseling is caused by having the throttle blades set too far open at idle. if you are running not enough timing at idle it will force you to open the throttle blades to compensate to get idle rpms to where you want. crank up the timing to 15, or 18* at least. then you can reduce throttle opening back to the right position. this should cure the deiseling.
I run my timing at 20 initial 0-600rpm, 38* 600 -3500rpm, dip down to 35* at 5000, then back to 37* from 6000 on. My engine has 9.5:1 compression though, and yours will probably like a couple degrees less since it has 10.5:1.
my $.02
Old Sep 27, 2010 | 06:04 AM
Pop N Wood's Avatar
How many miles on the motor?
Reason I ask is carbon build up in the combustion chambers contributes to this. Thus engine needs to be hot.
The cure back in the 70's was to use higher octane gas. That and a few high speed runs to "blow out the carbon". Worst case try leaving it in gear when you turn it off.
If our timing is wrong the engine could be running hotter than normal.
What 3pedals says makes sense also.
Old Sep 27, 2010 | 07:46 AM
1994t/a's Avatar
thanks for the input...i will try adding some timing and closing the base idle screw to get the rpms down.im gonna take the car to the track this coming up fiday for the first time and try to get the timing dialed in better.
its brand new...only has maybe 300 miles on it now.
Old Sep 27, 2010 | 09:21 AM
tennerv8's Avatar
My carbed 6.0 with L92's does this same thing. I have 28 degrees at idle. It only seems to do it if i rev it up right before shutting it down.
Old Sep 27, 2010 | 06:06 PM
ZONES89RS's Avatar
In-Zane Moderator
Mine does it if i run less than 93 octane, mine is a stock LQ4 with 317s milled ,030. I need to check it out as well.
Old Sep 27, 2010 | 07:41 PM
1994t/a's Avatar
Ive ran a steady diet of 93 in it pretty much.Only thing else its had in it about 5 or 6 gallons of sunoco 108 mixed with whatever 93 was in there which wasnt more than 2 or 3 gallons.It defiantly liked the 108 better than the pump gas.reason i tried the 108 though was it seemed like it was trying to vapor lock after driving for long periods then shuting the engine off and restarting after it sat for about 5 or 10 minutes.which in that amount of time it allows the carb to heat soak...the 108 kept it from trying to vapor lock....btw anyone on here got any experince with running leaded gas in carbed LS engines?mainly how does the lead affect the valves and such?ive ran it in old school sbc alot and never had a problem.
Old Sep 27, 2010 | 08:21 PM
3pedals's Avatar
lead wont cause any problems, unless your running a catylic converter.
Old Jun 23, 2011 | 06:50 PM
Wiese1's Avatar
A new product called CarbShot can help. Even though the YouTube video shows it being used on a boat engine, it will work on any carbureted engine.
http://www.youtube.com/watch?v=gV0Antm1Wl8
