carb on a 5.3 DOD engine,is it possible?
I have everything from the doaner truck to wire it up,but running into a very clutterd engine bay,and alot of unshure issues,thinking of trying to take the easy way out with a carb,not really concerned about fuel mileage,or the DOD to work,just wanting to try and make this thing come back to life in my S-10.
Does anyone know if i dont change the DOD internals of the engine,will it operate as if it just didnt have it with a carb intake?
Well i was wondering if its possible to leave the DOD lifters,and passages alone for the time being,would it work as a regular engine,the same as my Diablosport programmer turning it off,im looking at $2000 more by the time i get a TCI trans controller for 4l60 E,and im really not looking forward of pulling this thing back out right away,stock will be better than it just setting here,while my past year of saveing for just one more part never ends LOL!
I dont know the answer to that exactly.
I have read that the DOD lifters are rpm sensitive, so dont rev it past the factory shift rpm to be safe. If you are not signalling the DOD solenoids, it should run on 8 just as if the the dod was not activated, and it should run just fine. BUT I am not 100% positive about it, so keep researching before trying it.
Ive asked local tech. and got the same answer about the lifters not being for high performance,going from a 2.2 to the stock 315 hp 5.3 will be fine for the time being,after getting this thing going im shure then i will get bord and want a big bump stick.
Hopefully this is gonna work for now,THANKS
WOW! not what i wanted to find out,rojs234.But your right i did some reserch,and have to thank you for letting me know about the oilpump,thats one thing i would have never realized,and might of overlooked that part of a reserch or thinking it would of been good to have a better pump.
Looks as if i bombed on my choice of wrecked truck ,owell atleast i got a start with LH6's LS6 (243)heads and a decent 9 9.1 compression and aluminum block i spent all winter polishing.My parts list keeps growing.beginning to think the dude passed on that owned(wrecked) my doaner truck LOL!!he's haunting me.
Don't give up on that LH6......that's a fine little engine. The one we got came out of a '05 Tahoe and like your's is all aluminum GEN lV and has #799 heads (same as 243's). Luckily it was a 24X reluctor engine and since my friend wanted cable TB, we used an earlier 2002 intake set up and the 2002 wiring harness and PCM. I just got done lengthening the wiring harness so he could put the PCM behind the seat in his '51 Ford pick up. (big job!) I had already reworked the harness to stand alone from the instructions on www.lt1swap and we had already had it running. Should be going again in a couple days. Good luck on your S-10, whichever way you decide to go.
I wanted to thank you for the information,now that its complete,It was well worth saveing for,I included a couple pictures and a link to my YT video.
,https://ls1tech.com/forums/picture.p...ictureid=83652,http://youtu.be/zmd4ok37_Lw
It has a Thumpr cam (Comp Cams)It is the smallest of the 3 Part#54-600-11.
It has 2.5 mendrel bent pipes,2 original series 2 chamberd flowmasters,Personaly i like them at idle only,the super 44s sound alot better on LS engines.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
that thing sounds sweet! what valley tray do you have? also what ignition are you using? I have a 08 5.3 lmg that im putting in my camaro, I to am going with that cam, same intake, 750 holley? and the same ignition as you i think, is there any suprises i should know about before i put all the parts on? what carb are you running? thanks
I looked quickly but is the LMG a displacement on demand iron engine? I used a LS2 valley cover,My carb is a 750 Holley Ultra Double pumper,close out of the box,My ignition box is MSD 6LS-2(6012),Dont buy a intake MSD package im told there not capable to use software(laptop)buy them seperate,It will come with pills,I used the one closest to my cam for start up,and used it for arround 200 miles,was very easy.
As for surprises.Your actually working on a LS2 based engine rather than LS1 based,if it is a displacement on demand engine.You will have to change some internals.If it is go to LS2 forums,check out DOD Delete threads.I got 90% of a parts list with part #s there.
Is the LMG a DOD engine?
It doesnt run too bad,I just purchased caltracs,not for traction,but for safety.Durring a hard pull my leafsprings were rapping up so bad even at speeds of 85+ when letting off the fuel my rear tires were leaving the road.Funny after the slightly swaying pull all the way,the after effects are more scaryLol!.Havent got to try the Caltracs out yet.cant wait till spring.
