LQ9 Carb L92 Heads noise up top
I have a issue with rockers or lifters. short block has 150k on it.startup is fine but when u drive it and it gets to 160 degrees, it sounds like the rockers are backing off Running like the valves are not opening all the way.pulled the covers and rockers are fine. oil pressure is 15 at 900 rpm and 25 at 2000 and 45 at 3500. i just put new ls7 lifters in it 2 days ago and made it worse its happening at about 145 150 degrees. If i let it sit still for a couple minutes it comes back to normal while idleing as soon as i go a minute or less its back.
any help would be great thanks.
Junkyard lq9 all stock new oil pump from gm. cam from tsp around .580 lift. l92s with springs for the cam gm 5 layer head gaskets. victor jr intake aed 750 cfm. and 3500 stalled jw400.
im running 20w-50 now and with little change. all day today its been running 25 psi at 1000 and gose up slowly from there to 50 at 4000. i ran the motor to 6500 on a pass comes up to 65 70 psi under full load . so most likely bottoms worn out. but pushrods how do i check if there rite?
