Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Bogging off the launch
Old Nov 23, 2010 | 09:02 PM
3pedals's Avatar
I've got an NGK, its ugly, but it was $250, and the bright red display is easier to read when I have it mounted to my ice drag sled in the winter.
Old Nov 23, 2010 | 10:08 PM
283nova's Avatar
look up rob youngblood www.advancedclutches.com well worth the $ for a clutch.
also i would look into
ram sintered iron
mcleod softlok
or one of the mcleod street twins.
in a stick the clutch needs to take the shock. most serious stick car racers will have clutches with base pressures ranging from 350lbs to 1000lbs vs the 2200-2800 lbs clutches out of a catalog.
also the clear plastic sight plugs for a holley are not worth it, they are plastic and in time get brittle and break off. just use the screw.
Old Nov 24, 2010 | 06:48 AM
ZONES89RS's Avatar
In-Zane Moderator
The screw? That is messy as hell with all the camming at idle, LOL.
I have the centerforece dual friction right now. Since it is not intended for the track very often, i cannot justify a clutch swap.
Old Nov 24, 2010 | 06:49 AM
ZONES89RS's Avatar
In-Zane Moderator
Originally Posted by speedtigger
Keep me posted on the wideband purchase. I am looking at those options right now.
Trying to see what is the best bang for the buck right now.
Originally Posted by xpndbl3
i run the AEM uego and love it for how cheap it was and it's lasted 2 seasons so far with no complaints
Is that the plain old AEM from Jegs and Summit? That is the one i was looking at, the digital for 200$, does it work with a lap top as well?
Old Nov 24, 2010 | 06:55 AM
team39763's Avatar
LOL. I didn't believe that would really happen, but it just happened to me. I had my clear sight plugs for about 4 years and one broke off in the bowl last week.
The analog AEM is 159 at Summit right now.
Old Nov 24, 2010 | 03:23 PM
ZONES89RS's Avatar
In-Zane Moderator
Does that plug into a lap top with software to track the A/F ration?
Old Nov 24, 2010 | 04:44 PM
xpndbl3's Avatar
it has an output wire but no software to record data....so it's looking at the gauge only unless you are plugging it into something else like HP tuners to datalog. I haven't found anyone selling software that would record just a simple tach signal wire and the wideband cheaply at all.
Old Nov 24, 2010 | 04:47 PM
ZONES89RS's Avatar
In-Zane Moderator
Have you seen the Innovate motorsports piece? Comes with output wire and software for 200$ i think. Would really like to be able to log the data instead of watching a gauge while i am blasting in a straight line.
Old Nov 24, 2010 | 04:50 PM
ZONES89RS's Avatar
In-Zane Moderator
Well, i will look further, but i found this on the Innovate kit:
Program Cable (Only needed for Datalogging and to change the Fuel Type Setting)
Old Nov 24, 2010 | 04:54 PM
ZONES89RS's Avatar
In-Zane Moderator
Here we go:
Log directly from the LC-1s digital output into laptop w/included software:
Old Nov 26, 2010 | 12:30 PM
283nova's Avatar
if you do get serious best inevestment for a stick car is a driveline speed censor.
Old Dec 5, 2010 | 08:40 PM
  #32
LSwonderfull's Avatar
Jet extensions sound like part of your problem, just remember to use corresponding float with cutouts for extensions.
Old Dec 5, 2010 | 11:03 PM
  #33
ZONES89RS's Avatar
In-Zane Moderator
Yea, fixing to order a set, wish i had already.
Old Dec 16, 2010 | 01:31 PM
  #34
ZONES89RS's Avatar
In-Zane Moderator
Jet extension kit and notched float are in, hopefully i will make it to the track after i get LCARBs on as well.
Old Dec 16, 2010 | 09:50 PM
  #35
cody161's Avatar
who did you get them from and what brand are they if you don't mind me asking
Old Dec 17, 2010 | 06:10 AM
  #36
butler's Avatar
I would get a better fuel pump and run a larger fuel line. I launched my mustang on the same gears you have and it never bogged even at 6000 rpm launches. The gearing in the tranny and rear end keep the rpm's up. Are you running a dp or vac sec carb?
Old Dec 17, 2010 | 08:12 AM
  #37
speedtigger's Avatar
Old School Heavy
Back in the day when I raced stick shifts, I had the best results with some tire slippage. I would increase the tire pressure until I had a enough tire slippage to keep the RPMs up. This was sooooo much easier on clutches too.
Old Dec 17, 2010 | 08:20 AM
  #38
ZONES89RS's Avatar
In-Zane Moderator
It is a eBay jet extension and notched fuel bowl kit, neoprene or whatever you call it.
It is a pro form main body 750, double pumper, the Holley blu works fine but the next engine will get a totally upgraded fuel system.
Old Dec 17, 2010 | 11:32 PM
  #39
butler's Avatar
Check your accelerator pump adjustment. Fully dpressed on the linkage should still have little clearance. You may not be getting a full shot. Just a thought.
Old Dec 18, 2010 | 03:32 AM
  #40
ZONES89RS's Avatar
In-Zane Moderator
Acc pump has nothing to do with it launching off the 2 step, the pedal is to the floor.
