Bogging off the launch
It is NOT because you dont have jet extensions. The reason you are bogging, is because something in the transfer of power HAS to slip at least a little, and in your case nothing is.
I cant remember what kind of tires your running, but I'll assume you are dead hooking. Your clutch is designed NOT to slip, so it grabs hard and fast, and brings engine rpm down in line with wheel rpm. In order to get the car to leave cleanly you need to introduce some slippage.
If you dont really have a good idea where to start with rpm I suggest 45-4800rpm, and try to maintain this as close as possible - a 2 step is really the only way.
If your running bias tires, you need to air 'em up to around 20ish psi and make sure they spin on the launch. Then carefully lower psi each run, until you find the bog again, then go back up to the psi where it didnt bog, and you got just enough wheel spin to let it all work.
There is another way to do this, use a slipper clutch. It is what I run. It takes some more maintenance than a regular clutch, and it also requires adjustment between street and track, but it is the ONLY way I have acheived 1.60 60ft on drag radials with a stick shift. If I put slicks, or bias et street's I could leave WAY harder than I do now, and not bog OR BREAK ANYTHING, because the slipper clutch takes out the violent hit to the driveline and tires.
Barrett
Do you have a 2 step? it will beREALLY hard to find the sweet spot where it will spin "just enough" without one, the difference between spin and bog can be 200rpm(where the cam gets happy). raise your launch rpm if you cant find the happy medium, that will give the engine an advantage over the tires. And then again sneak up on the tire pressure where it hooks.
Have you done all the front suspension tricks to this car to get it to weight transfer?
I been through all of this, and I frickin hated how touchy it could be, thats why I went to the slipper clutch, it really solves this problem. You may have a hard time using 1 with your t-56, as it is so wide where it matches the belhousing, you may not be able to drill a hole in the right spot on the bell to adjust it.
Dont give up on drag racing the stick shift!
I just noticed that 5500rpm is where he is leaving, if it is still dead hooking at that rpm, then add more rpm, but also air up the tires a couple pounds,
Something NEEDS to slip a bit.
Have you checked the pinion angle?
I am running 4.30 gears on a 26x11.5x16 ET street, the pinion angle is at 3*, no wheel hop.
This happened the last track outing when i tried to slip the clutch at 6000 on the two step, but instinct made me dump the clutch because i have trained myself to do so on the two step for some reason. Kind of like shifting when the shift light comes on, you just shift by instinct, i told myself not to dump the clutch, but when the green was dropped, i went with what i have been doing for so long when the two step is activated.
If you can introduce tire spin on your launch, then you can dump the clutch just like you are used to, and creep up on the right tire pressure to get enough traction back, in order to get the car to 60ft without bogging.
Again, this is not easy. Thats why there are VERY few guys who run a stick at the track, guys are just too lazy to shift there own gears nowadays
PS have you ever checked out the UMTR? The forum is dedicated to Stick Shift racing
http://www.umtrnorth.com/forums/
