how to wire ls1 fans with no ecm???
I need to wire my fans & I had the fans for when I was fuel injected but never finished the swap fuel injected I switched to a carb & want to keep the fans...do I just need to get a plug to plug into the to plug wholes on the fans or what?
I have a 96 fbody that has a carb'd small block 406 and I use a be cool thermostatic fan switch that comes on at 180 and shuts off at 160 and it is great. I used all the stock wiring to the car and just ran the one wire from the switch itself to the ground side of the factory relays to kick both fans on high at once. only thing is is that they stay on for a minute or two after shutting the car down but I use a good battery and it never has any problems.
