Popular Hot Rodding Engine Shootout
In the February 2011 issue of Popular HotRodding, there is a "Muscle Car Engine Shootout". In this article they have top engine builders competing for the highest average horsepower & torque between 2500 - 6500 RPM on pump gas. The test contains several LSX based engines. The most notable competitor was Racing Engine Design that fielded a 426 ci LS7 headed entry producing 643 horsepower at a mere 6200 RPM and a thunderous 600 ft lbs of torque at 4800 RPM.
Anyone else see this issue?
Check-out the torque of the Ford Boss 429 stroker motor. There are several Boss motors but the one on page 52 made 608 ft/lbs@2,500 rpm and still 521@6500. That's more than most diesel engines and 4,000rpm range over 500 lbs/ft. In a 3,000lb car with a 2,500 stall 2.73 gear, MY GOD look out.
Aleck
Aleck
Aleck
Aleck
I have respect for what theese guys can accomplish on the dyno FOR SURE, but EM competition is definitely producing some dyno queens
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Very true. Look at the DNQ's on the web site. Just like we run no oil in the rear-ends, just coated gears while making record runs. Because of coatings and new cyrogenics ( I think spelled wrong) we also only run 2 qts of oil in the motor. We weld every seam on the body in Pure Stock to help the chassis. We slow/limit the timing on some cars to help the bias ply tires hook. Limit timing until 5,000rpm, short shift 1st, 2nd then go to 6,500-7,000 in 3rd, 4th. What ever works.
Did you know a 305 crank is 5lbs lighter than a 350?
4.3 v6 chev rods are 5.98" and the pistons are same bore as 350?
Lighter crank = rpm
Longer rod that has GM part# and piston. Most tech's seem to miss this.
Need more??
LOL
Aleck
Lighter crank = rpm
Need more??
LOL
Aleck
Lighter crank = rpm
Need more??
LOL
Aleck
Lighter crank = rpm
Need more??
LOL
Aleck
