Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Performer RPM VS Victor JR Dyno test
Old 01-21-2011, 06:37 AM
Old School Heavy
speedtigger's Avatar
Am I on Yellow Bullet?
Old 01-21-2011, 09:05 AM
Prorac1's Avatar
LOL, Touche', lol. Eric L
Old 01-21-2011, 06:41 PM
Old School Heavy
Originally Posted by ZONES89RS
Yea, i have to agree, that is a tiny cam compared to some of us and will make power down low still. My Trex swapped into it would be a whole different ball game.
I would like to see that test. We can probably guess the outcome but it would be interesting nonetheless.
Old 01-21-2011, 06:51 PM
In-Zane Moderator
ZONES89RS's Avatar
Either way, the low end idle quality no matter what is probably better and part throttle cruising is, im sure, a plus.
Old 10-11-2014, 06:10 PM
66-sd-BBB's Avatar
Bringing this back from the dead . Does anyone have a link to a stroker build , using aftermarket heads and the performer RPM? I'd like to see some dyno results.
Also , as a project I was going to pull the intake and grind out the webbing to make it more pretty, like the Victor . Anyone done this ? I'm not sure why Eddie and Holley leave the casting webs on the dual plane intakes.
Old 10-12-2014, 10:36 AM
sssuch's Avatar
I did this to a Holley along with a full polish , lots of work to get it looking right.
Attached Thumbnails Performer RPM VS Victor JR Dyno test-corvette-pic-1062.jpg   Performer RPM VS Victor JR Dyno test-corvette-pic-1063.jpg
Old 10-12-2014, 10:43 AM
sssuch's Avatar
Here's a couple more pics before I bolted it on .
Attached Thumbnails Performer RPM VS Victor JR Dyno test-corvette-pic-022.jpg   Performer RPM VS Victor JR Dyno test-corvette-pic-024.jpg
Old 10-12-2014, 12:58 PM
66-sd-BBB's Avatar
Nice work ! Do those Holley intakes perform better than the Performer ?
Old 10-12-2014, 05:01 PM
sssuch's Avatar
It's supposed to , but if I had it to do all over again I would of bought an Edelbrock Performer RPM. Holley is cast in china , Edelbrock right here in the USA. This is important to Me , had I known I would of got a Edelbrock. Also Edelbrock appearance is much nicer out of the box. I also opened up and polished the insides of the runners , so it would be kind of hard to compare the performance between the two.
Attached Thumbnails Performer RPM VS Victor JR Dyno test-corvette-pic-026.jpg   Performer RPM VS Victor JR Dyno test-corvette-pic-027.jpg
Old 10-12-2014, 05:55 PM
66-sd-BBB's Avatar
I agree with you there. Capitalism is flawed in many ways, and I encourage buying local , whenever we can.
Apparently the Performer RPM have supported up to 590 HP , but I haven't found the build thread yet .
Old 10-12-2014, 07:05 PM
Old School Heavy
https://ls1tech.com/forums/generatio...rtin-tick.html
Old 10-12-2014, 07:14 PM
  #32
Cstone812's Avatar
Originally Posted by DCx
do you guys think i will benefit for an intake swap? i am currently running a victor jr, cnc ls6 heads, and a MS3 cam shaft on my LS1. backed by a stage II T56 and LS7 clutch, currie 9" with 4.11 gears. it already pulls like a no other past 6500. just wondering if i will get more usable power for street driving. although i would love to see what my car can do at the strip, i doubt i will ever drag race it. hood clearance is pretty tight under my cowl hood on my 69 camaro. how much shorter is the performer?
From my understanding a FAST intake benefits cams such as those much better. Single plane intakes like cams somewhere in the 108 lsa range.
Old 10-13-2014, 04:24 AM
  #33
Horsepwraddict's Avatar
I absolutely love this. I havn't had the opportunity or funds to build a lsx that I felt could take advantage of a single plain but I have always enjoyed building dual plane motors. It may sound dumb but I like my little street car motors. A lot of people are surprised how well my motors perform for what they are and I like to chalk it up to putting together combinations that work well together. Its been a long time since I seriously drag raced but nasty race motors made me appreciate putting together motors that make power under the curve. I also only ever had experience with screaming big blocks and big converters so I have yet to experience all that these ls motors can do.
I have been watching this and matt K's thread because its exactly what I want to do for my car eventually. Sorry for the rant, I just find this very intriguing.
Old 10-13-2014, 05:00 AM
  #34
66-sd-BBB's Avatar
Matt K 's build is good news for me and my goals, as I want to stick with my dual plane. The Performer Rpm isn't a restriction for making 590 useable HP at 6000 RPM . Add a 100 shot at the track, and hang on.
Old 10-13-2014, 05:58 AM
  #35
I would love to see side by side comparisons at the track. Im willing to bet it holds up pretty well in the right setup. With a lower rpm motor I bet the added torque on hand after the shift helps a lot, maybe sacrificing a few mph but who cares. Slightly easier on parts too if you can get away with a lower launch rpm.
a 550 ft/lb motor with a stick behind it would be a sickly fun street car.
Im really curious to know what my baby 5.3 would do with a set of heads, 228 ish cam on a 110 and a performer rpm with my 650 on top. I think it would be real fun.
Old 10-13-2014, 10:52 AM
  #36
Old School Heavy
I actually did track test the Performer RPM vs the Victor Jr. On mild LQ9.
Old 10-13-2014, 02:37 PM
  #37
66-sd-BBB's Avatar
Did 10 more HP and 20-30 less torque improve your driving experience and track times ? When I go stroker , a tighter converter will probably work better . I went 3600 because that seems to be the most common around here , and it does feel quick. 3200 would probably work really well with a dual plane , as your 2800 does too.
Old 10-13-2014, 03:53 PM
  #38
Old School Heavy
In my car I really did not notice any difference in drivability with the 3000 rpm stall on the street as my car could easily overpower the drag radials at speeds below 30 Mph.
At the track, the Victor Jr. was .05 slowerer in the 60' than the Performer RPM, but 1 MPH faster by the end of the 1/8 mile. The car ended up running roughly the same ET in the 1/8, but was 1 tenth quicker and 1.5-2 MPH faster in the quarter mile with the Victor JR.
This test was done with a very mild 222/224 camshaft, 3000 stall and a 3.90 gear. It is my opinion that the decision between Performer RPM and Victor Junior is all about the stall converter. On a 6 liter I would choose a Victor Junior on anything with a 3000 stall or higher unless the vehicle was #4000+ or had a very low numerical rear axle ratio.
Old 10-13-2014, 04:04 PM
  #39
66-sd-BBB's Avatar
My car is over 3600# with me in it , and has 28" tall drag radials , so with a relatively small engine , the performer seems to work well. I would try out a Victor if I had one.
Old 10-13-2014, 05:15 PM
  #40
Old School Heavy
My race weight during those tests was #3750.
Quick Reply: Performer RPM VS Victor JR Dyno test
