2 Cams 1 Choice
I have an Edelbrock 2215 Cam (220° Intake/224° Exhaust/.510'' Intake/.510'') Exhaust on order or should I go with a Comp Cams Thumpr (219/233Duration, 553/537 lift). If you had your choice ,which one, Plain and simple. The car is just a driver that's built for handling and just plain fun. Would like good sound , driveabilty and a broad power band. Opinions on these 2
but if it was me i would also mill the heads and use a thinner l33 5.3h.o/5.7 head gasket for improved quench and higher scr and improved power and tq.
The thing that gets me about the thumper cams is the huge exhaust duration compared to the intake. In Comp grinds for LS motors, that seems to be pretty unique to the Thumpr series.
The LS6 Springs are rated to .570 wouldn't those work too since the LS6 cam has .550 Lift
My advice to someone else with this question would be to go conservative, which means going with the Edelbrock, but the Neanderthal in me says, go Thumpr.
